Question about Kitchen Appliances - Others
Foodsaver vac 750
My foodsaver 750 will make a seal. The vacuum starts but does not **** air. Any suggestions?
5 Suggested Answers
WilyWonka
  • 5 Answers
SOURCE: Foodsaver V2440 won't vacuum air out
If your FoodSaver is more than a couple years old, the gaskets have probably gotten compressed. Especially if you use it often or store it with the lid in "latched" position.
FoodSaver's website has replacement gaskets, $3 each, but it's hard to match the right gasket with the V2440. I called and got confirmation: it's this one. http://www.foodsaver.com/Product.aspx?id=r&cid=0&pid=294
Same gasket, upper and lower, even though it's listed as "Upper" on the Web page. You can also call them at 877-777-8042 and order Part # T910-00075.
Meanwhile, I've had good luck with soaking the old gaskets in warm water for a few minutes, then letting them air-dry. It seems to restore their sealing power for a day or two at most, but that's enough for me to vac up my weekly freezer groceries.
Posted on Jul 14, 2009
SOURCE: My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Posted on Nov 21, 2009
  • 88 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 731 Answers
SOURCE: foodsaver V845 is not sealing?
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Posted on Jan 24, 2011
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
I have a Foodsaver 2840 that will vacuum and seal, but not seal alone. The manual button does not work (though it worked earlier today). I have tried everything. Any hints?
Hi donnaj615...
Start the vacuum and then immediately click on the seal button...
I have a 750 that does the same thing...
Please take time to rate me
Aug 13, 2011 | Tilia FoodSaver V2240
The Vac runs and runs but does not seal. Can you order a replacement seal unit in Canada and where?
Practically speaking, before you start thinking about spending money on replacement parts, please visit here:
http://www.foodsaverblog.com/
You will see a comprehensive list of models and prices.
Then you can decide what to do.
You can also check here: http://www.foodsaver.com/Index.aspx for your nearest retailer of parts and supplies.
May 23, 2011 | Tilia FoodSaver VAC420
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
Tillia Foodsaver VAC 370 won't stop vaccuming to seal
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Feb 16, 2009 | Tilia Kitchen Appliances - Others
Dec 30, 2008 | Tilia FoodSaver VAC420
Kitchen Appliances - Others Logo
110 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
