Question about LG Computers & Internet
Itek music player doesnt switch on
I plug it in to the mains socket then switch the on switch on the back of the tower to on and they doesnt seem to be any power to it anymore
SOURCE: peugeot 307 04 plate
just disconect leads on cd changer should reset
Posted on Dec 19, 2008
SOURCE: Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Posted on Dec 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: my mp3 player doesnt download music anymore.
This player is not compatible with iTunes or certain types of protected WMA's. Use songs that are only in Mp3 format, and make sure you are transferring while the player is in MTP Mode.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
SOURCE: GPX ML648B mp3 player main menu problem
To get back to the main menu just hold the mode button on the side
for a couple seconds or so. You'll get back to the main menu where
you can use the up or down volume buttons to get to settings and folders.
To see all your folders select the top (root) folder and wait a few seconds.
You'll be able to figure it out from there.
Posted on Jun 06, 2009
  • 47 Answers
SOURCE: when listening to music the system shutsdown
You COULD have faulty hardware that cant take the power coming through the electrical, Its a warranty fix
Posted on Aug 15, 2009
Itek jukebox plays for maybe a minute or 2 then dies.
Locate the main amp since it does it on all functions. It will be on a big heat sink. Chances are it's a single IC type possibly marked STK. See image below. If it is I would replace it.
May 22, 2016 | Audio Players & Recorders
Trying to get my Labtec to work. Computer does not see it.
If you are taking the sound output from the green output socket on the back of your tower, then your speakers must be powered by a mains adapter.
You will have a black main adapter similar to a mobile phone charger, and the output from that on a thin wire will plug into one of your speakers, normally the one with the volume control on it.
To test if the speakers are powered up and working, plug an MP3 player into the green plug that goes to the speakers, does that play ok?
Apr 24, 2014 | Labtec AM-242 Microphone
Itek 15003
Contact the maker or talk to someone in another shop hope this helps
ddmac19
Oct 25, 2013 | Cameras
Fujitsu tower smoke out of rear no power
Sounds like you need a new power supply. Have a look at the labels on the old one inside the tower. The thing to look for is the total power output in Watts.
If it's 300watts for example then buy another with the same or higher wattage, I would go for a higher one. Then check the leads that come out the back in to the drives and motherboard etc. Especially the power to the motherboard. If it's a 20 pin socket thats the standard, if it's a 24 pin socket thats the more modern type but can still be used on a 20 pin connector on the motherboard, you just don't use the other 4 pin plug thats usually seperate at the end of the plug. The power supply is usually only held in place with 4 screws on the outside of the tower.
The main power connector to the motherboard has a little clip on the side of the plug that you have to press in to remove, it's like a little hook to stop it comming loose. There may also be a black and yellow wire 4 pin plug near the pocessor heatsink on fan, that also has a clip to press.It's not a hard job, just take your time and don't apply to much pressure when connecting the new leads to the board.
Feb 05, 2012 | Fujitsu Computers & Internet
I NEED TO HELP WIRING MY COMPAQ HOME COMPUTER
Set all items up ready to be installed Plug in your mouse and keyboard into the back of the tower. If u are using the old style connectors these have pins and will also be colour coordinated so you know where to plug into tower. They will have a notch inside so plug in carefully so not to break pins. If they are USB connections they will be square at the end and u will see where these plug in at the back of the tower these do not have colour coordination as u can plug in anywhere. Next your VGA cable, this is the cable that looks the same both ends with 15 pins in it. One end goes into your monitor and the other into the back of the tower these are shaped so they only fit in one way, again caution that you do not force in as you could bend the pins. Next ensure u have the power leads into the tower and the monitor, these are the cables with a plug on one end and a female 3 hole socket at the other, u will see where these plug into both devices. Next plug into wall ensuring socket is off first Then switch on Switch on your tower....monitor should come on by itself, if not hit the power button on your monitor Voila ...done
Oct 27, 2011 | HP Compaq Evo D310 PC Desktop
PC would not power on? My PC wouldn't power on today, I checked all plugs on surge protector inc the fuses all seemed ok. I took all plugs out turned power off at socket for five minutes and put all plugs...
The tower has a self contained power supply module that is the problem, it must be replaced for a new one, you need to bring the tower to a computer repair store for service, because they have to install the correct power supply for your model.
Jan 25, 2011 | Computers & Internet
How do i delete everything off of my emerson mp3 player?
all you do is hit the reset button on the back of your mp3 player
Jan 26, 2010 | Emerson BAR900 MP3 Player
None of the buttons work. No music, can't eject and doesnt play the cd. Thanks in advance
HI, this is totally main board failure. try to unplug for 3 minutes then, plug back in after the three minute shutdown. if this continues, replace the main board(control).
May 22, 2009 | Aiwa Audio Players & Recorders
Pc wont power up
Is there an on off switch on the back out the computer next to the main power socket? If so move it to the on position.
Check the mains lead and make sure it is firmly inserted in the socket.
When you press the front panel on button and it doosn't boot up and there is no light indicating power, then you have a faulty switch mode power supply.
Remove the switch mode power supply and replace it with a new one with the same wattage or greater wattage.
May 07, 2009 | eMachines D3415 PC Desktop
Computers & Internet Logo
35 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
