Question about Toys
Chevy wont start
Why Chevrolet s-10 4.3 wont start when cold
    Sergeant:
  • 340 Answers
Other than the fact that GM products are, as a rule, cold blooded in the best of times, your problem could be sourced in many areas. I would first look at the choke, which is probably automatic and closely tied to the computer. That is why you don't pump the excelerator on these newer rigs. GM products also have some redundant systems to prevent burning up your engine. The foremost is the oil pressure switch that shuts down the fuel pump if oil pressure is to low.
Posted on Aug 11, 2014
What would cause you to lose fuel pressure while driving.
Chevrolet S-10 Questions - Fuel System Loses Pressure ...
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusJul 28, 2012 - Fuel System Loses Pressure - I have a 2003 Chevy S-10 Pick Up with the 4 ... car a few times, what essentially you are doing is priming the fuel pressure. ... A dirty fuel filter will not cause the lines to lose pressure after the engine is shut off. ... I have a 98 s10 2.2 liter and it was driving fine all day then when ...
Chevrolet S-10 Questions - My 2001 S10 has a hard starting ...
CarGurusSep 16, 2012 - My 2001 S10 has a hard starting problem if the truck sits between 1 ... Vacuum leak, have you checked fuel pressure while it sits? ... Would the spider alsocause a misfire at low rpms? .... at an idle, or squeaking while driving and it gets faster as you go? ..... 1994 Chevrolet S-10 2 Dr STD Standard Cab LB.
Chevy S-10 Won't Start - Repalced Fuel Pump and Pressure ...
www.cartruckinfo.com/chevy-s10-wont-start.html
Chevrolet S-10 pickup won't run and has no fire unless I jumper the fuel pump relay. ... Once the truck starts and is running you can remove the jumper to the fuel pump ... Iwould get the fuel pressure checked to start with, because that's where the ... 93 gmc 4.3l FI runs but dies out loss of power after 5 mins of running then ...
Stalling S10: I Have a 1994 Chevy S10 2.2l It Stalls After 35 ...
Dec 10, 2015 | 1994 Chevrolet S-10
1998 chevy cavalier replaced ignition cylinder instrument panel stereo car wont start when its cold
You have a short to ground inside the steering column Measure voltage with ignition off.any wire that has less than 12 volts should be considered as problem if not black in color
Mar 19, 2014 | 1998 Chevrolet Cavalier
I have a 1995 chevy s10 4.3 when cold it will crank and idle only then when it gets warm it wont even act like it wants to start its getting gas and fire to the plugs and coil
is your ck engine light coming on, if not ck for fuel pressure when not starting, possibly fuel pump problem if you have no check engine light on
Sep 01, 2013 | 1995 Chevrolet S-10 CA Edition
93 Chevy blazer S-10. Doesn't want to start
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Chevrolet
Dec 08, 2017 | 1993 Chevrolet S-10 Blazer
1997 chevy s-10 wont start easy
might need your injectors cleaned. or check your fuel filter. or your fuel pump is going
May 01, 2010 | 1997 Chevrolet S-10 Pickup
2003 chevy impala starts cold and runs well but then it wont hold the speed it looses speed and won't accelerate over 23000 rpms
This can be your catalytic converter. If engine has no power, and won't go very fast, and you have your foot to the floor, this is the likely cause. The car may be covered by a Chevy extended warranty for this known defect. The warranty is 10 years 100K miles on that particular part for that failure. Take it to a dealer and they should fix it for free.
Apr 18, 2009 | 2003 Chevrolet Impala
1985 C-10 chevy pick up- wont start at all
My 85 silverado was doing the same thing last week. After a few days of that B.S. I ended up replacing the fuel pump and filter and she's been running great since,
PS. The fuel filter is located at the carburator.
Jan 09, 2009 | 1985 Chevrolet Chevy
Toys Logo
41 people viewed this question
Top Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
