Question about Maxi-Cosi Familyfix Base Isofix only
Why is the bottom of the isofix base is not level with the seat?
Why is the bottom if the isofix base not level with the seat?
  • Maxi-Cosi Master
  • 1,629 Answers
Hi Andrew
It is not possible to diagnose without inspection.
Was the unit approved for use in your vehicle on our online fitting list?
Was the unit physically fitted by a carseat fitter trained member of staff to confirm suitability prior to purchase?
Please contact us with further information so that we can best assist.
Dorel UK Customer Service
Posted on May 12, 2014
  • 419 Answers
SOURCE: Hi, weare missing the bars that fit under the
If you purchased the carseat without the bars, then this is a Cabrio and not a CabrioFix carseat, and nothing can be done to adapt this to become a CabrioFix.
I hope this helps.
Posted on Sep 15, 2009
  • 419 Answers
SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Posted on Oct 12, 2009
pan_stak
  • 182 Answers
SOURCE: how do you remove the isofix base from the car
Every ISOFIX base has a button which you can press and release the base from the car seat.
Usually it's a round one at the junction of the ISOFIX base and it's LEG
Posted on Jul 29, 2011
Dorel UK
  • 1629 Answers
SOURCE: Hi, I would like to ask
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Posted on Aug 08, 2011
Dorel UK
  • 1629 Answers
SOURCE: Can the isofix easyfix base
Good Afternoon
The yellow plastic IsoFix guides are for assistance only when fitting the unit and make no difference to the performance. If you are able to fit the base so the indicators go green it is fine to continue using without the guides. Alternatively if you need replacement guides they can be ordered via your retailer or direct from our customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Posted on Nov 10, 2011
How to remove the isofix base from the car seat
Hi
Is it removing the carseat from the base or removing the base from the car that you're having difficulties with?
Feb 03, 2013 | Maxi-Cosi Familyfix Base Isofix only
Maxi-Cosi Familyfix base Isofix base warning beep
Yep, there's a switch underneath to turn off the sound, but the lights will still work.
Jan 31, 2013 | Maxi-Cosi Familyfix Base Isofix only
Hi, I just installed the isofix base Maxi cosy isofix without the yellow adapter. Know I am worried this could be a problem without using the, Does all users have these on? Is it necessary?
Hi - The yellow plastic guides are only for your conveniance if you need them. Some cars have very prominant IsoFix points and you do not need to use the guides - this is fine. As long as the indicators go green to show correct fitting it is fine.
Sep 24, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Can the isofix easyfix base be used safely without the isofix guides, ours are missing, thanks.
Good Afternoon
Sep 10, 2011 | Maxi-Cosi Priori
How do you remove the isofix base from the car seat?
Jul 29, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
The yellow anchor points that attach to the car fittings and then the isofix base fits on to them. where can I get 2 more
If you mean the plastic caps that click onto the isofix points in the car, then you can buy these on eBay, just search for ISOFIX GUIDERS.
I hope this helps.
Sep 26, 2009 | Maxi-Cosi Priori
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
I hope this helps.
Sep 25, 2009 | Maxi-Cosi Baby Gear
Fitting an isofix car seat in a ford cmax 57 plate tdi
if there are a small part of the backseat (ca 10 cm high located at the bottom of the back) that can be picked out, you have isofix points.
if your backseats are in one pice, theres not
Apr 11, 2009 | 2007 Ford Focus (3 Door) Hatchback
Maxi-Cosi Familyfix Base Isofix only Logo
145 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
