Question about Hotpoint 24 in. HDA3740G Stainless Steel Built-in Dishwasher
My hotpoint LFT114 slightly fills then stops any one got any ideas? the water is like a warm puddle at the bottom and the tablet is released, but no spraying the dishes ever begins.
Please help, i dont have a call out fee!
  • 183 Answers
SOURCE: Hotpoint FDW60 problem
Wash motor either seized up/ faulty or the is an itme jamming up the impeller. Regards Advisor
Posted on Aug 31, 2007
SOURCE: FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Posted on Nov 05, 2007
SOURCE: Hotpoint Aquarius DWF31
Hello Burmanator,
I had to call a angineer in the end.If your problem still going on.You can try what engineer did it.Turn the dishwasher on and press the program end button (quick wash and normal wash button in the same time). you should hear a pump out water sound.Wait until finish and display 0 again.Than swich off the machine.wait little bit than turn it on again and press a program button.If your problem is over fload device activated like mine.You shoud hear to begin working and getting water in.
It cost me £40 to bring the angineer in and press these two button.5 min.job.Good luck
I hope this information help you.
Posted on Jan 16, 2008
SOURCE: not enough water going in or draning properly
air brake blockage more than likely the cause.
see air brake systems in haynes dishwasher manual
Posted on Jan 20, 2008
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
When my dishwasher finishes it no longer lets out 3 beeps and when you open the door there is no power even though the dishes are clean.
Hello J Arnott,
Sorry to say I'm here in the USA.. and I could not easily get a similarly designed model to reveal itself (for me) to gain a better understanding of your Hotpoint LFT114... (nor could I pull a FREE copy of your user manual (without registering or otherwise exposing myself to cyber-freaks (sorry)).
Regardless of the specifics.. suffice it to day your machine is NEW enough to be quite visible and relevant...
I looked over the LFT114 HA... Display board... £42.93
(there are many LFT114
And your trouble description was quite excellent in detailing
as SEQUENCE failure of your control modules...
Although it is possible to repair these things ... it seems you have several PCBs (printed circuit boards)... replacement is usually the first best GUESS (looking at the back () side would not hurt anything)...
I have rescued many a circuit board by simply "de-soldering"...
then re-soldering a connection...
(special care, skill & tools required... not tough nor expensive).
You description and troubles indicated the beeps & lights missing: is a clear indictment of your "DISPLAY board"...
A reminder... don't touch any PCB you value without first grounding your hands (professionals use STATIC WRIST STRAPS... CHEAP (unlike circuit boards) & available EVERYWHERE).
Also... Take lots of pictures of EXACTLY WHERE every wire comes from... (look them over BEFORE you get in trouble).
Be patient & FORCE nothing.
and of course... be safe (REMOVE POWER).
Comment me back BEFORE you guess wrong... (I'll try to help) .
Spares:
Hotpoint LFT114 HA PCBs Modules
Jul 15, 2016 | Hotpoint Dishwashers
Leaking and fan stops then starts?
Don't know if this will help but our fridge was leaking and then I noticed there was ice at the bottom and it was clogging a drain hole so the water ran out on the floor in front of the fridge. I chipped out the ice, melted the drain hole and slightly raised the fridge temp so the ice would not re-form on the bottom and it worked. - no idea about the fan.
Jan 17, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My washing machine , a hotpoint wdd960 , wont stop filling with water , i had problem since the frosty weather when water froze. i have took top of machine and all electrics are soaked, it is 3 years old ....
you will find at the drum bottom there is a 5mm pipe leading to the water censor remove it and blow gently into it you should hear a click and one when you release the air this means that the censor is ok but the small pipe where you took the pipe from is blocked not allowing the air pressure to build up to tell the controller that water is full enough to continue to the next cycle clean out the small pipe with a pipe cleaner, dry the parts of the machine with a hair dryer eric
Dec 26, 2017 | Washing Machines
I keep seeing a puddle of water at the bottom of my GE Profile refrigerator. I traced the water line, and it is not coming out of that. I cannot locate any drain pan. However, I can see a 14 x 16 sheet...
the drain is stopped it is just under the evaporator a hole in the center pull out draw you will see it. blow it out .may have to chip some ice away or use hair dryer to melt
Oct 03, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Leaking water at the discharge line/selinoid???
If it is coming out the bottom of the door (ie around the bottom seal, it may be the dish washing powder. Had this issue on one machine and simply changing back to the one the manufacturer recommend stopped the puddles forming. I think it is due to the power being too sudsy and creating excess bubbles
Apr 13, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
My refrigerator is leaving a puddle on the floor
Hi. The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker/dispenser, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here, in return, causing the puddle you have discovered.
Nov 21, 2009 | GE Refrigerators
Water under side by side hotpoint
You can deal with it once for all by pouring warm water into the drain pipe to clear any blocks and sopping it off with a sponge..
Oct 29, 2007 | Hotpoint HSS25GFP Side by Side...
FDW60 dishwasher
Oct 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. HDA3740G Stainless Steel Built-in Dishwasher Logo
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
