My hoover platinum max extractor carpet cleaner has no power
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Can you expand on "no power"
Posted on May 31, 2014
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Help! My boyfriend took apart my hoover platinum carpet cleaner
That sucks! Um, if you do not have the manual, here it is
http://hoover.com/file/622/
If that does not help. you can contact Hoover
https://hoover.com/contact/
Flick the boyfriend
May 08, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
FH50005 carpet cleaner stopped running after 2minutes of 1st use.
Hi Rae! You may have a tripped breaker or blown fuse if the cleaner shut off your first two minutes of use. Replace fuse and reset breakers if needed. Also check that the plug is plugged in firmly into the outlet. If the cleaner still won't turn on we recommend taking it in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Nov 12, 2014 | Hoover FH50005 Quick & Light SteamVac...
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
Aug 30, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
How do I use my Hoover Max Extractor 77 on furniture
you must read the instruction manual. If you do not have download from Hoover. com and proceed according
God bless you
May 16, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
What kind of upright or steam Vac should I buy which can make my carpet clean and SOFT?
I recommend looking at the miele S7280 for an upright vacuum cleaner and the royal RY7910 carpet extractor.
Jan 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
My hoover carpet cleaner's brushes dont roll, it is a steam vav power max
They may not be "stapped" in postion correctly. Do you have the manual?
If not go to: www.hoover.com for a free copy.
Mar 15, 2009 | Hoover F6213-900 SteamVac Agility...
Which is the best caprpet steam cleaner mid priced?
I would recommend the Hoover brand. The Bissell's are very problematic, they have belts that break and issues with the heating elements. Hoover Steam Cleaners can be repaired and are simple to use. The price range is generally $180 - $300
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
