Question about Troy Bilt 175HP Manual 42" Riding Mower
What are the valves supose to be sat on with my troy bil riding mower
Im having to turn the flywheel with my hand in order for my mower to crank think my valves are off
It may seem simple, but be sure that your battery has a full charge before you try to crank it. I would try that before I started tearing down the motor.
Posted on May 11, 2014
  • Troy Master
  • 2,478 Answers
YES, adjust valves. What motor?
  • Dennis Key
    Dennis Key May 11, 2014
    If valves isn't adjust right, the compression didn't release.
Before. My Troy riding mower stopped running I was having to hold the pto lever down for it to start
adjust valves and make sure flywheel is in alignment with a new straight key
Sep 17, 2016 | Troy Garden
Craftsman lawn tractor with 18 b&s ohv motor blows dipstick out while cranking. Valve lash is good.
check to see if the flywheel key has been sheared off. if so replace it
Sep 13, 2016 | Craftsman Garden
Why does my Craftsman rider struggle to crank?
You said valves are OK, but did you mean not leaking and seating properly or correct tappet clearances? Check the valve tappet adjustment. If they are slightly tight the engine will be hard to turn over.
Aug 23, 2014 | Craftsman Garden
Turns over will not start
check for spark if you have no spark. you will probably have to replace the ignition coil
Apr 21, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
My lawn mower is trying to turn over but won't completely. we have replaced the starter, battery, and spark plug. why will this not crank and turn over?
It probably has a faulty starter solenoid which won't allow full amperage to the starter. Also the valve clearances need checking because if they are too loose the built in decompressor will not work and allow the engine to crank over. Regards Phil
Apr 15, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Pull mower rope on troy built self propelled mower and it jerks it back out of your hand,hard,,and will not start
This sounds like the engine is out of time.
Usually this happens when the blades hit something hard and shears a small aluminum"key" between the crank shaft and the flywheel.
This is reparable. The little key is less than a buck. A person needs some skills to remove the flywheel to replace the "key".
Wayne
Jul 30, 2010 | Troy Garden
I have a 24 hp briggs, model 445777, type
I believe this does have comression release. Make sure you're rotating the motor in the correct direction, as I think the compression release only works in one direction. Adjust the valve to .004 with the piston at TDC make sure it's on the power stroke. Turn the motor till intake opens, then when you continue to rotate crank, unitl valve closes and piston gets back to TDC. Adjust both valves to .004. Then do the other cylinder the same way.
Jul 21, 2010 | Briggs & Stratton Garden
Troy-Bilt Mower is running real slow like its clogged dont know not a mower expert, need help please before I take it to a mower expert.
If you can, check the flywheel key. If it is bent but not quite broken, it can cause slow operation. To do that, take the starter off the top of mower. Take off the big nut on the flywheel. Find a nut of the same size and place on the thread you took the nut off, but only a few turns. Hold the flywheel with one hand, lifting a little, and tap the nut with a hammer with the other hand. The flywheel should come off. Look at the key, it holds the flywheel to the shaft. If it is bent or broken, that is the problem. Replace it and go about your day! Good luck...Lee
Sep 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Jul 31, 2009 | Garden
Help With Troybilt Ride On Lawn Tractor
check your crank case for fuel,
bowls stick open an fills it up
if this is the case , you can buy a plastic fuel cut valve from lawn mower shop
todays fuel isn't very good
also try sta-bil fuel coditioner
May 30, 2009 | Garden
Troy Bilt 175HP Manual 42" Riding Mower Logo
81 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
