Question about Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-900BC water leak - Cuisinart DGB-600 Coffee Maker
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • 6 Answers
SOURCE: DGB-600 grind & brew thermal coffeemaker
  • 3 Answers
SOURCE: Where do I purchase replacement charcoal water filters for my coffee maker?
I found replacements at Bed Bath & Beyond
Posted on Oct 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart dgb-500 automatic grind & brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart DGB-650BC instruction manual
Here's a link to the manual:
http://www.cuisinart.com/share/man/1013_man.pdf
-Tha Mp3 Doctor
Posted on Mar 22, 2009
I just purchased a DGB-900BC unit. Coffee temperature is really not hot.
See page 10 of your user's manual; if you misplaced it, go to:
Cuisinart DGB 900BC Instruction Booklet Page 10
If the instructions listed half-way down the page don't help, contact Cuisinart customer support, or return the coffee maker to the store you bought it from.
Feb 21, 2017 | Coffee Makers & Espresso Machines
How can i get manual for Cuisinart dgb800bc
Hi Harrison, The links below are user manual for a dgb900bg and a user manual for a dgb600dg..... Could not find an 800 mate......... CHEERS..
https://www.cuisinart.com/share/pdf/manuals/dgb-900bc.pdf
http://www.cuisinart.com/share/pdf/manuals/dgb-600bc.pdf
Apr 29, 2016 | Cuisinart Coffee Makers & Espresso...
I have purchased DGB900BC on amazon. I didn't realise this machine was for American use. I am in Australia , what can I do to convert the voltage?.....Brigitte
Everything you need to know about running North American appliances Down Under can be found here: http://www.aboutaustralia.com/travel-tips/power-adapters-australia-new-zealand/. Good Luck, mate.
Sep 13, 2014 | Cuisinart DGB-900bc Grind Brew Thermal...
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
DGB-900bc will not grind; It also does not pull the beans into the hopper to grind them. It used to make a loud grinding sound when it ground the beans, but now it makes just a dull sound, like the grinder...
I experienced the same problem after many uses. You need to pull the hopper off and clean out the path the grounds take to the filter basket. It is no doubt clogged up. I used compressed air to really clean it out good.
Good Luck
Mar 21, 2010 | Cuisinart Coffee Makers & Espresso...
Cuisinart DGB-900BC filter basket brew pause spring came out. How do I fix it?
You can push the soft rubber stop or valve back on the plunger stem with the flat side down. It can pull out if you are rough with it or if the plunger gets stuck in your dishes drip rack. But if it is torn you need to order a new basket because I don't think the parts are sold separately.
Jan 12, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Jul 17, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
101 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
