I'd like to get some examples using macros for the Remote MX-950
I'd like to get some examples using macros for the MX 950. I have three devices that have a single command to turn it on and off. I'd like to jump from one setting like cable-Denon-tv to McIntosh-sacd or McIntosh-Netgear-tv to listen to MP3. I am having a hard time to get the macros to work correctly. I appreciate any help.
    President:
  • 1,114 Answers
Your best bet for the best help is at www.remotecentral.com That's where the Pros hang out.. I do Crestron,Lifeware,RTI and Logitech, I don't do too many Universal's. They have a whole forum dedicated specifically to the MX remotes. Hope this helps
Posted on Jun 23, 2009
Having a problem changing channels imputing into MX 3000 remote. Takes about 5 time to react to channel imput.I thought a new battery would help. It did not. Would rebooting the remote in the cabine
Presuming that the IR codes for the 0~9 numbers are captured correctly, then problems like this are usually down to either insufficient time between key presses, which can be solved by adding a small macro delay to each key; or the device being controlled is receiving multiple IR streams either directly from the hand unit and the IR emitters, or there's a blaster in the cabinet that's bouncing IR in multiple paths.
Sep 04, 2014 | Universal Remote Control MX-3000 LCD...
I can't download software for my MX-950
It seems to have compatibility issues with Win7. On your PC right click on your MX icon, find the Compatibility tab and select Windows XP.
Or you can download Windows Virtual PC from Microsoft. This will allow you to run Win XP programs on Win 7.
http://windows.microsoft.com/en-GB/windows7/install-and-use-windows-xp-mode-in-windows-7
Apr 19, 2014 | Televison & Video
Mx780 volume control not working at all other macros work.
Check it by set it up with an other code to your device brand.
Aug 20, 2013 | Universal Remote Control MX-780 48-Device...
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
I have a Vizio Model XVT3D554SV TV that uses a bluetooth technology remote. I have been unable to get the MX 500 to learn from the TV remote and cannot find the code for the TV. I would like to use the MX...
2. Auto Scan With Three-Digit Number
You can also program your remote control by sending out a
series of Power Off commands for different brands stored
in the library by using the following steps. This is similar
to the first method, except it is easier to move through all
of the device codes for your device and make note of each
one that turns your device OFF.
1. Manually turn on the device you plan to operate.
2. Go to the SETUP mode by pressing both the MAIN and
ENT buttons simultaneously for three seconds.
3. Press the P-PRO button next to the LCD screen.
16
17
4. Programming the MX-500TMto Control Your Components
4. The remote will be flashing "SELECT BUTTON".
Press the device you wish to program. (For example, to
program TV, press the TV button.)
5. The remote will be flashing "FROM TABLE". Select the
device from which the scanned code will be selected.
(Important: If you have already relabeled your device
keys, your LCD screen will not look like the illustration
above. Select the appropriate LCD button for the "FROM
TABLE" using the labels as shown in the illustration on
page 11 of this manual. For example, if you have relabeled
AUX as LIGHTS, you would still push the bottom-left
button to access the AUX Code Table.
6. Point the remote control toward the component and
alternately press the UP (or DOWN ) button on the LCD
and the Power button. If the right code number is sent, the
component will turn off right after the code number is
transmitted.
(Please press the UP (or DOWN ) button within 20 seconds
of beginning programming, otherwise the remote will
revert to the SETUP menu, and then after a period of time,
it will go back to the MAIN device page.)
18
7. Confirm that it is the right code by pressing the Power
button. After you have confirmed that the right code is
entered, save the code by pressing the SAVE button on the
LCD.
8. Confirm that you entered the right code number that
matches your component by pressing other functional
buttons. If any of the buttons do not operate, as they
should, please repeat from Step 1.
9. Continue to program other components by repeating
from step 1 above.
10. You can press EXIT at any time if you do not wish to
proceed.
11. Exit from Preprogrammed mode by pressing the MAIN
button and then exit from the SETUP mode by pressing the
MAIN button once again.
Sep 14, 2011 | Universal Remote Control MX-500 LCD Remote...
COD
In computer science, mobile code is software transferred between systems, e.g. transferred across a network or via a USB flash drive, and executed on a local system without explicit installation or execution by the recipient. Examples of mobile code include scripts (JavaScript, VBScript), Java applets, ActiveX controls, Flash animations, Shockwave movies (and Xtras), and macros embedded within Microsoft Office documents.
Mobile code can also download and execute in the client workstation via email. Mobile code may download via an email attachment (e.g., macro in a Word file) or via an HTML email body (e.g., JavaScript). For example, the ILOVEYOU, TRUELOVE, and AnnaK email viruses/worms all were implemented as mobile code (VBScript in a .vbs email attachment that executed in Windows Scripting Host).
In almost all situations, the user is not aware that mobile code is downloading and executing in their workstation.
Mobile code technologies can be used to support three different paradigms:
Mobile code can also be encapsulated or embedded in other file formats not traditionally associated with executable code. An example of this form of encapsulation is the presence of JavaScript in a PDF.[1]
Mobile code also refers to code "used for rent", a way of making software packages more affordable. i.e. to use on demand. This is specially relevant to the mobile devices being developed which are cellular phones, PDAs, etc all in one. Instead of installing software packages, they can be "leased" and paid for on a per-usage basis.
please comment on this post stating how it help you with your phone
Dec 21, 2010 | Motorola Mobility I335 Cellular Phone
Where can I purchase a Lithium battery 046067 for an MX 3000?
Do you favorite search engine and type your model number and then batteries. What I got is www.buy.com
Aug 18, 2009 | Universal Remote Control MX-3000 LCD...
Remote Control Programming my MX-3000
Hi Jimmy, we do programming for several types of universal remotes all across the country. Once a client visits our site, www.totalcontrolremotes.com, and fills out a new customer form and downloads, fills out, and emails us their configuration we can give them a quick estimate, eta, and mail them back a configuration file. We also are unique in that we offer a lifetime contract for changes made in case the customer adds or subtracts equipment, has channel lineup changes, wants something else set up, etc. We provide many graphical, simple to use and most of all enjoyable custom designs.
Visit our website www.totalcontrolremotes.com for more details. We will be glad to help you with any of your programming needs and do quite a few MX-6000, MX-3000, MX-980, MX-950, MX-900, MX-880, all the way down the line. We also do many other types of remotes as well and I am sure you will find our pricing very reasonable.
Thank you,
Vincent
Total Control Remotes
Universal Remote Programming & Advanced Control Systems
Feb 26, 2009 | Universal Remote Control MX-3000 LCD...
MX-950 Universal Remote
Have not yet received a solution to my question.
Jan 08, 2009 | Universal Remote Control MX-950 LCD Remote...
52 people viewed this question
 Grubhead
Grubhead
