Question about Kitchen Ranges
Why does my CDA cooker hood not work? - Kitchen Ranges
3 Suggested Answers
  • 142 Answers
SOURCE: CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Posted on Jan 27, 2009
SOURCE: charcoal filter for cda cooker hood only number i
I had the same problem. No information in the user manual or on the internet about what filter to use. But actually, its not a problem at all because the filter is a universal one! B&Q sell 3 or 4 universal filters, the important thing is to choose the one that has the same diameter and the same central fitting. The one you need is made by Designair and says on the label "suitable for models VH60S, VH60W, IH60SS. It only costs £4.95.
Posted on Aug 28, 2010
Fan on cooker hood does not work but light works
It it new? Maybe the fan connection in the connection panel come loose or was not done properly from factory. Turn off the breaker to the hood and inspect the wires and connections, if all is good, then maybe the switch needs replacing. Good Luck!
Jun 25, 2012 | Kuppersbusch Designer Island Canopy Cooker...
Charcoal filter for cda cooker hood only number i have is TYPE IN1KB1BS Ref INT/CIN installed nov.2005
Mar 10, 2010 | CDA PISCES CPP9 Kitchen Hood
Cooker hood motor failure lights work extractor motor just hums no movement is it brushes in motot ?
probably gummed up from oil and grease if u have access to the motor use a spray lube and spray the shaft as it goes into the motor case this should free up the bearings -if no access remove motor clean than oil up motor turn motor back and forth by hand and will free up replace and test
Feb 10, 2010 | CDA Cooktops
Cda extractor stopped working, could the fuse have blown
it is very possible but more than likely the motor went out
Sep 26, 2009 | CDA Kitchen Ranges
Cooker hood
Look around on the hood and cooker for a small fuse. If you find one, replace it with one of the same type and rating.
Apr 16, 2009 | General Electric Stove/Oven/Range Chrome...
Where do I put the charcoal filter?
It would fit over / into where the other filter goes the charcoal filter is to help eliminate more smoke and grease
Feb 10, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Jan 26, 2009 | CDA Kitchen Ranges
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
