Question about Brother DCP-7020 All-In-One Laser Printer
How to get rid of dark black lines on the printed copy?
4 Suggested Answers
  • 37 Answers
SOURCE: Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Posted on Dec 17, 2008
leroyal
  • 2120 Answers
SOURCE: Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Posted on Jan 25, 2009
qwertyisone
  • 6 Answers
SOURCE: Bold black lines across the paper when printing,scan or copy not on faxing
I realise this is probably too late for you Janet and you will have bought a new drum unit by now or replaced the printer! The three lines appeared on my print-out from a new drum I installed and after investigation it transpired that there was some toner residue that had dried on the drum (from testing at manufacture stage probably) and reprinted three bold lines on a sheet of A4. The solution is to use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Posted on Aug 19, 2010
How do I get rid of black line on the printed copies on Canon IRC3580i when printing
If it happens when printing and copying then its either a drum, itb, cleaning blade or fuser issue. Sorry its not a one answer question.
Mar 02, 2015 | Canon Office Equipment & Supplies
Problem with copy/scan from Feeder
clean that small glass on printer if problem still continue open all machine and try blow it blower machine!
Apr 25, 2012 | HP Officejet 4500 Wireless All-in-One...
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
A line appears down the length of the page on all copies, printing and scanning. How do I get rid of the line?
All you need to do is clean the top feeder which opens into two parts. make sure you clean the black rollers as well as the small strip of glass you will find when you open the second part of the top feeder . don't be afraid to pull open the top feeder it won't break
Jun 01, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Brother DCP-7020 All-In-One Laser Printer Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
