hi i couldnt find asus eee pc 4g black's inbuild cam installer or software as well as drivers for free download, plz sugest me earlier as soon as possible if u have solution just contact me on plus sign than nine one nine eight nine eight six one eight six one four my contect no.
For some unknown reason the bios seems to just turn off the camera. This has happened on the linux versions and may happen on the XP versions too.
Solution: (by memory as I can't check this and type this too) 1 Reboot your machine and hit the F2 key (repeatedly, every second or so) very early oin the boot sequence to bring up the bios window. 2 select the hardware section and check that the camera is enabled. If not enable it and exit with F10 which will save the settings.
Check if your laptop has inbuilt recovery partition.
Also if you have recovery discs you can reinstall the cam application since most of the inbuilt softwares that come with your notebook will present in the Recovery discs or Recovery partition.
when tyring to turn on goes straight to message re; insufficent resources then tries to restart and...
(More)
when tyring to turn on goes straight to message re; insufficent resources then tries to restart and message pops up again
asus eeepc 4g white screen on lcd nothing visible but output ok on external monitor output.tried Fn...
(More)
asus eeepc 4g white screen on lcd nothing visible but output ok on external monitor output.tried Fn F6 to change goes off external monitor but does not change white screen Lcd any ideas please
my eee pc's camera goes all sepia and green shaded whenever i use it on skype or other web cam...
(More)
my eee pc's camera goes all sepia and green shaded whenever i use it on skype or other web cam applications, how do i fix this?
