Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice maker making loud noise for exrended times on fridgidaire
Ice maker has a deep hum and goes on for about 20 minutes on a regular basis.
  • 3 Answers
Water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
Posted on May 12, 2014
  • 957 Answers
Replace the ice maker that would be cheaper then having it worked on
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
SOURCE: Loud Buzzing noise
What fan?and does it run only after the ice maker cycles?
Posted on Jul 30, 2008
  • 8 Answers
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Posted on Feb 20, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
  • 72 Answers
SOURCE: Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Posted on Jun 15, 2009
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
How do I get the icemaker to make ice
TROUBLESHOOTING ICE MAKERS.
Nov 23, 2014 | Refrigerators
Every 20 seconds it makes a loud noise like a pump being activated
Sounds like the compressor trying to start. Is it making any ice?
Apr 05, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
I have a GE side by side refrigerator with ice maker. Refrigerator has been fine and now it just started making a loud like humming noise which is coming from the freezer the ice maker works when I open...
Sorry to read about your problem, I hope this helps you out.
it maybe your fan, going bad. or you have a ice build up, and its hitting the fan..if this is the case, you have a defrost issue. or a bad fan.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
MOTOR NOISE AFTER ICE CUBES DROP - LASTS 2 OR SO MIN UTES The noice is not always the same - sometimes steady hum as if small plane is going over - lasts a few minutes. Sometimes noise is loud for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Amana DRS2660B Side by Side Refrigerator
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Our kenmore elite bottom freezer is making a loud humming noise. It shuts off when door is open..and continues when door is shut. Temperatures are fine, no error message, it rarely stops..like it is trying...
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Sep 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
609 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
