Question about Sylvania LC320SLX 32 in. LCD TV
What screws for back of Sylvania LC320SLX?
What size screws are needed for wall mounting the Sylvania LC320SLX?
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
  • 10 Answers
SOURCE: remote code for att uverse to sylvania lc320slx lcd tv
My solution might be a little off because I called Comcast for the answer but it seems that the problem is that the code doesn't exist.
I called Comcast and they had no clue. But I called Sylvania and their reps were FABULOUS!!! Turns out, the TV makers send the cable companies the frequencies for each TV then the cable companies send them to a 3rd party to get the codes written.
This model of TV is new and there is no code written. The rep suggested that we countinue to check back on the Comcast website regularly to see if the code is posted. She said that the sales reps tend to get the info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
Posted on Dec 20, 2009
  • 10 Answers
SOURCE: I need a remote code for my Sylvania TV. LC320SLX
The Sylvania rep anticipates a new code written soon because this is such a prevalent problem.
budmrtn
  • 11361 Answers
SOURCE: bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 05, 2010
SOURCE: we have a LC427SSX and want to mount it on the wall
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
Posted on Aug 01, 2010
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
Mount screw size
To get this detail, you have to download the repair manual to this set. Its, disassembly section, will have the details. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 14, 2013 | Sylvania LC320SLX 32 in. LCD TV
Can i wall mount my 32" LC320SS8 sylvania tv by the 4 screw holes in the back of tv
Yes, with a mounting kit. A plate screws to the TV using those holes, then attaches to another plate that's attached to the wall.
Jul 06, 2011 | Sylvania LC320SS8 32 in. LCD Television
How do you Wall mount a Sylvania LC370SS9 TV
If you have a wall mount kit, it is fairly simple. You just find the place that you want the tv to go and find a nearby stud to install the mount. After that you will want a second person to help with either holding the tv up or screwing in the tv to the mount. There are four screw holes in the back of the tv to screw through the wall mount plate into the back of the tv. Check to make sure it is stable, then you have successfully installed the tv to your wall
Jun 17, 2011 | Sylvania LC370SS9 LCD TV
Bolt size
Jul 04, 2010 | Sylvania LC-321SS9 32 in. LCD TV
Best wall mount for sylvania 6842thg plasma
To make it simple: Mounts go by the size of the TV.
You have the choice to get a standard mount that can only swing or a mount that can swing and tilt or even extend. Plasma TVs are a bit heavier, than LCDs therefore, you need a solid mount. There are wall mounts and ceiling mounts. Mounts can be purchased from Home Depot, Lowe's and best buy, they can also be bought on line. If you buy it from a local store and does not fit, you can take it back the next day, an option you wont have if you buy online.
Good luck
N Sabre
Nov 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
We have a LC427SSX and want to mount it on the wall
Jul 09, 2009 | Sylvania LC420SS8 LCD TV
Sylvania LC320SLX 32 in. LCD TV Logo
44 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
