Question about Craftsman Garden
Connect clutch cable to activate mower blade
Model 917.288520 where do i connect the the clutch cable on the lower end to activate the blades. I checked the diagram but it didnt show what it connects to. Can you help me.
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
SOURCE: I have a craftsman 42
Hi
The part number for just the shaft is 137646 and for housing shaft and bearing is 130794.
Sam
Posted on Jan 07, 2010
  • 3 Answers
SOURCE: MTD 46 '' mower deck 190-806-000 blade brake control cable missing
The cable connects to the pin on the deck brake assembly and the other end connects to the pin that hangs downward from the upper idler assemble. Each end is held in place with a washer and cotter pin.
Posted on Jul 07, 2012
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
MOWER BLADE DOES NOT DISINGAGE
You need to replace the blade clutch cable that runs between the blade engagement lever just to the right of the steering wheel and the the spring to the idler/clutch wheel on the top of the mower deck. Over time the cable binds in the sleeve/cable jacket preventing the blade from disengaging
Aug 18, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
I have a 1988 Model 26624, 21" Key-Lectric mower. I've noticed over a period of time that the mower blade slows considerably when cutting the lawn. At first, I thought it may be grass accumulation under...
Yes, it sounds like you need to adjust the blade brake clutch (BBC). I have a PDF service manual that explains it. If you post your email address I can upload it to you. Here's an excerpt from the manual:
BBC
BBC Adjusting the Blade Brake
1. Stop the engine. Pull the wire off the spark plug.
2. Remove the two screws securing the screen
panel to the top of the mower housing as shown
in Figure 22. Remove the panel. (The panel they're
referring to is the red screen between the motor
and handle.)
3. Move the control bar down and lift up against the
handle. With the control bar against the handle,
measure the spring length (L) at the front of the
spring as shown in Figure 26.
4. If the spring dimension is greater than 32 mm
(1-1/4") an adjustment is needed.
5. To adjust, loosen the bottom jam nut on the blade
brake cable as shown in Figure 27. Adjust the top
jam nut until spring dimension is as near as
possible to nut; not less than 25 mm (1") See
note below.
NOTE: Adjusting the top jam nut too high can
cause the cable end to crush the plastic fitting
when the control bar is moved up against the
handle. If the spring cannot be adjusted to less
than 32 mm (1-1/4") before the cable end
contacts the plastic fitting, the clutch belt is worn
out and should be replaced. After replacing the
belt, adjust the cable per the above procedure.
NOTE: 1990 and newer models are equipped
with finger tip adjusters that do not require tools.
Use the same adjustment criteria on these
cables.
Sep 18, 2010 | Toro Lawn Mower With Toro Power Tools
Dead battery
The blade clutch is electric. A bad battery might be interfering with the clutches engagement. You should make sure you have good contacts on the battery at both ends. Replace any battery cables that are excessively corroded. If the battery had removeable caps for filling you might want to check the electrolyte levels and top them off with some distilled water. You can also jump start your mower and check the voltage while running with the blade off. If you dont see voltage going up while the engine is running you probably have battery and charging system issues. The battery should have at least 12 volts with the mower off and 13-15 volts with the engine on.
A bad charging system would require repairs on the motor and should be handled by a local repair shop. At least you can rule out the diy stuff first though right?
Good luck and be caeful. Wear eye protection whenever working around batteries with jumper cables. Weak batteries give off explosive gases. Always connect the cables to the bad battery first and then the good battery to avoid sparking near the bad battery.
Jul 25, 2010 | Husqvarna 54'' Package Deal Zero Turn...
Oct 09, 2009 | Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
Garden Logo
15 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
