Question about Craftsman Garden
Lawn tractor model 917.288520 i removed the deck to sharpen blades. disconnected the the clutch cable to activate the blades. I cant remember where to connect it to by the deck. I checked the diagram it shows the cable but not where it connects to. Can you help me.
Peuhayd
  • 11 Answers
SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
4x4papa
  • 14 Answers
SOURCE: riding lawnmower blade
First, always wear safety glasses and hand protection when working on machinery. Also include my favorite saying; "Common Sense Prevails". No amount of overgrown lawn is worth getting hurt. Work on as flat a surface as possible, always chock the tires in both directions to prevent movement and disconnect the negative battery cable making sure it will not contact either battery posts while working on the mower. This will insure the engine will not start on it's own or the mower move of it's own accord. Release the parking brake, with the shifter in "neutral" position. Check your tire chocks and make sure the mower is not going to roll in either direction. Now, lower the deck to it's lowest position. Now loosen any guide pins that extend from the underside of the main chassis that keep the belt from coming off the drive pulley on the engine. Again, there may be one or more. Remove the belt from the pulley. Now find the linkage that tightens the belt when you engage the blades. It should extend from the chassis at an angle to the deck. If your mower is equipped with a PTO (power take off) clutch that engages the blades by a switch on the dash, skip this step. Now remove the clips that secure the raising\lowering arms from the linkage at the top of the arms, not the deck end. This will allow you to slide the deck, slowly and carefully out from under the mower, with out the arms "dangling" from the mower interfering with the deck. You will have to adjust the angle of removal as you are sliding the deck as most have an "attack angle" that is not 90 degrees from the strait line of the mower from front to back, but is angled more forward on one side or the other. Once the deck is clear of the mower, depending on the size and weight you can lift it (with help) or use a floor jack to raise it (being VARY careful not to contact the blades) and lower it onto 4 blocks at least 4 inches high. Place the blocks at the 4 "corners" of the deck. Two blocks long enough to run past the length (front to back) on both sides of the deck will work as well. Remove the covers on both sides of the deck that cover the belt\pulleys on top of the deck by removing the bolts that secure them. Most are a self tapping type, some have nuts and washer on the underside, and some have studs welded to the deck, so you don't have to reach underneath. Some tractors have one of these covers, some two, and some non at all. Clean the top side of the deck with high pressure water from a garden hose, or a pressure washer if you have one. Be careful of flying debris. There may be rocks, pebbles or other items that can become flying missiles and injure you, or someone close by.Flip the deck over, again being careful not to trap your (or your volunteer's) hand between any moving parts and the deck (like between the sharp side of a blade and the deck housing) and place on your blocks in the same position. You can now access both the nuts holding the blades and the top side  of the pulleys that either have nuts as well, or are made to accept a wrench or socket. Using a block of wood, ("2 x 4" x 12" is a good size but adjust the size to fit your particular deck) insert the block between the deck and one blade on the side of the blade that will stop it when loosening the nut holding the blade, making sure to get a good "bite" so it will not slip when pressure is applied. You can also use a wrench or socket on the pulley retaining nut on the top of the deck to stop the blade from moving as they both employ the same shaft. A volunteer to hold this is a good idea, perhaps a must. Make sure to equip them with safety gear as well. Apply a good lubricant like PB Blaster to the retaining nuts on the blades. Allow at least 15 minutes to absorb. Using either a 3/8" air gun or ratchet, or if using hand tools, a 1/2" breaker bar with the proper size socket of an impact grade, loosen the nut holding the blade. Your volunteer can help by hold the deck as you apply pressure to the bar. An extension of the breaker bar's handle with a piece of steel pipe having an inside diameter not much bigger than your breaker bar, and no more than a couple feet in length can be applied for more leverage, however this should only be done by someone with experience using the technique. Better to use air tools or a proper extension than bust up your hand by a slipping ad hock device. Remove the nut and washers, keeping them in the proper order for re-installation, and remove the blades noting which side is up and down. The cutting edge of the blade is always the lowest part of the blade when attached. Clean the underside of the deck. You may have to include a scraping tool as grass buildup can become quite hard over time and appear to be part of the deck. Pay special attention to moldy, wet grass around the blade shaft. This kind of moisture can induce corrosion prematurely to the deck housing and the bearings\shaft housing. Look closely for any type of wire, line from weed eaters, cables or any line that can be picked up by the mower and can wrap around the blade shaft between the blade and the deck. This line can eventually work it's way into the bearings, causing the bearings to fail.  Carefully inspect the shaft, bearing and it's housing for damage, corrosion, etc. Repair\replace as needed. Remove any surface rust with a wire brush (hand or power) again watching for flying debris. Inspect the blades, looking for obvious impacts that have caused visible damage to the blades. If found, remove the blade shafts and check to be sure they haven't been bent. If they have, don't try to straiten them, but replace them. A bent shaft will have caused undue wear on the bearings, and a straitened shaft will be weak where the bend was. A failure of the shaft, bearings, or bearing housings can be fatal if the blade becomes detached and manages to fly out from under the mower while in use and strikes someone nearby. Now sharpen the blades, or replace them if needed. An experience blade sharpening service should be employed as the angle of the cutting edge and the level plane on which they travel is critical. Simply using a grinding wheel will not give you anything but a sharp piece of steel, but will cut unevenly. Clean any buildup from the blades and the shaft's mounting platform for the blades as rust or any foreign substance will cause the blades to be at an improper angle. While the deck is removed, inspect the holes where the raising\engaging linkages attach looking for wear to the hole or the linkage shaft. Replace if any undo wear is detected. Check for side to side movement of the pulley\blade shafts indicating a worn shaft or bearing. Replace if needed. Check the bearing housing the shaft travels through on the deck for electrolysis corrosion cause by dissimilar metals in a moist environment), cracks or other damage. Replace as needed. Inspect the deck belt for wear, cracking or age and replace if needed. It's always a good idea to replace it regardless when performing this deck//blade service. Reassemble in the reverse order of dis-assembly, using Loctite red on all threaded surfaces, and greasing any available grease fittings. Apply a coating of graphite lube or grease to the linkages where the attach to the deck an mower. Make sure all fasteners are tighten to proper specs. Lift the deck to it's highest setting, engage the parking brake, and reattach the battery. Start the mower and engage the blades checking for any undo noise indicating loose parts. Check the deck movement by lowering to different settings always listening and feeling for vibrations or noises. Should everything be in order, you may consider leveling the deck for optimum cutting performance. But that's a different question........ Best of luck, and please indicate your rating of this solution if appropriate. Thanks so much, Papa
Posted on Nov 18, 2008
  • 41 Answers
SOURCE: blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
Posted on May 29, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
  • 13 Answers
SOURCE: wiring diagram for craftsman lawn tractor model
944.601140 Sure this is right number?
Posted on Sep 29, 2009
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
MOWER BLADE DOES NOT DISINGAGE
You need to replace the blade clutch cable that runs between the blade engagement lever just to the right of the steering wheel and the the spring to the idler/clutch wheel on the top of the mower deck. Over time the cable binds in the sleeve/cable jacket preventing the blade from disengaging
Aug 18, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman dlt2000 20 hp kohler runs great until i try to engage blades pull up on the switch to engage and motor bogs and stalls
Now is a great time to remove the deck and sharpen the blades! In the process, you will find your problem. Look for clogs, seized bearings, freely rotating belts, etc... The problem is in the deck or drive belt. Hope this helps!
Sep 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Gary
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to remove deck on 1045 cub cadet to remove and sharpen blades
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
Mar 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades will not disengage on lawn tractor
Your cable clutch is not engaging properly. Try to lubricate it with some grease. This will get the cable to slide. If that does not help, it will need to be replace.
Jul 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
116 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
