Famous Trails Discriminator Ii Metal Detector by Logo
K
Kevin Smith Posted on May 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Md 3006 metal detector
Not used for a while,batteries ok.when turned on marker is on non-ferrous all time and light is showing same.tried tuning but nothing changes.just making same tone all time
Shawn Hudson
Level 2:
Sergeant:
  • Expert 190 Answers
  • Posted on Feb 28, 2018
Shawn Hudson
Expert
Level 2:
Sergeant:
Answers
190
Questions
44
Helped
72279
Points
980
The Bounty Hunter QSIGWP Quick Silver Metal Detector, you will find out that it fully automatic ground balance that has squelch-tech to eliminate false signals when using it. You will definitely like it since you will get the quality that perfectly works for if you need a quality purchase. Those who have bought it have always been satisfied with the way it works when they need a perfect quality.
Bounty Hunter Land Ranger Pro Metal Detector Review Detectorly
Ernest Taliaferro
Level 2:
Novelist:
Scholar:
  • Expert 197 Answers
  • Posted on Jul 29, 2014
Ernest Taliaferro
Expert
Level 2:
Novelist:
Scholar:
Answers
197
Questions
0
Helped
65943
Points
278
Try hitting the reset button to center the needle in the meter then adjust the sensitivity knob to lower the sensitivity. Double check all your switches to make sure they're where they should be.
Finally, remove the batteries completely. If they're not alkaline, replace them.
If none of this helps, check the web to see if Famous Trails offers customer service or technical support. If they do, contact them to see if they know how to solve the problem.
The third option is to take it to a local electronics repair shop. The circuitry on metal detectors, especially the low end ones like Famous Trails, is not terribly complicated and a good electronics guy should be able to fix it fairly inexpensively.
Be sure to get a repair estimate then weigh the cost of repair against the cost of replacing it with a new one.
I've had this happen to my low end metal detector and when I went through all of the original set-up steps, I was able to clear the problem up myself.
  • Ernest Taliaferro Jul 30, 2014
    One other thing. Make sure a silver coin or magnet has not somehow locked onto the coil. Rare earth magnets might register as non-ferrous. I can usually get the needle to center even when it's legitimately detecting something. When I can't, it's because the sensitivity switch has gotten accidentally twisted to high sensitivity which makes it buzz continuously.
Does anyone have a manual for the Radio Shack / Tandy / Micronta 63-3002 metal detector?
I was out at event with my Nokta Legend at the weekend!
My first detector was a Radio shack in 1988. I think it had three dials, one for Volume, one for Sensitivity, and finally one for Discrimination, Ferrous one way, Non Ferrous the other and All Metal around the 12 o'clock mark. And the Red Button in the handle tip.
There isn't a manual available, but this post explains what the red button does and sounds the equivalent of Ground Balance / EMI Cancellation to zero the meter.
https://groups.google.com/g/sci.electronics.equipment/c/ncVCsDKRZp0?pli=1
https://www.google.com/search?q=Micronta+%2263-3002%22+metal+detector
2answers
What metals do not set off a metal detector?
Non-Ferrous metal is non-magnetic metals (copper, aluminum, brass, lead, etc.) It will take approximately 50% more of a non-ferrous metal to be as detectable as a ferrous metal. Manganese is also a non-ferrous metal and difficult for most metal detectors to detect. Elenco Metal Detector With Beep Alert Review Detectorly
2answers
What is the working principle of a metal detector?
Mainly metal detector is used to find hidden object or treasure. It may be precious metal or non precious metal as like non ferrous in non magnetic things. The operation of metal detectors is based upon the principles of electromagnetic induction. Metal detectors contain one or more inductor coils that are used to interact with metallic elements on the ground. The single-coil detector illustrated below is a simplified version of one used in a real metal detector. Best Waterproof Metal Detectorin 2017 Reviewed By Expert
2answers
What metals can be detected by a metal detector?
Non-Ferrous metal is non-magnetic metals (copper, aluminum, brass, lead, etc.) It will take approximately 50% more of a non-ferrous metal to be as detectable as a ferrous metal. Manganese is also a non-ferrous metal and difficult for most metal detectors to detect. Best Underwater Metal Detector In depth Guide Reviews For 2018
Can brass be detected with a metal detector?
Non-Ferrous metal is non-magnetic metals that copper, aluminum, brass, lead, etc. It will take approximately 50% more of a non-ferrous metal to be as detectable as a ferrous metal. Manganese is also a non-ferrous metal and difficult for most metal detectors to detect. Expended brass rounds should be quite easy to find with just about any inexpensive detector. Try your local on Radio Shack, they usually have Bounty Hunter machines in stock. Brass shell casings ejected and laying in the grass should send a loud, easy to pinpoint signal. I have been fortunate in being witness to the volunteer honor guard at Camp Butler National Cemetery on several occasions over the years so I feel compelled to say "Thank You" for your dedication and patriotism for our fallen military brethren, new and old alike. Bounty Hunter VLF Metal Detector Review Detectorly
IS THER A VIDEO THAT SHOWS ME HOW TO DO THE SETTINGS ON A MICRONTA 4003 VLF
It is one of the simplest ones to use. My niece used one for a while. I could not find a video but here are the instructions;
Instructions
    • 1Turn the metal detector on with the "Volume" knob. This also adjusts the level of sound.
    • 2 Check the batteries. Turn the "Test" knob to the Battery 1 or Battery 2 position and confirm that the needle points to the green area. Then turn the knob to "Nor" for normal operations
    • 3 Hit the red "Auto Tune" button on the carrying handle with the head portion of the detector away from any metal objects, and turn the "Tune" knob until the needle hits 0.
    • 4 Turn the "Sens" knob to the middle position.
    • 5 Turn the "Mode" knob to VLF (very low frequency), and turn the "GND" knob to account for the type of ground (such as dirt or sand) you are using the metal detector for.
    • 6 Turn the "Mode" knob to either the TR1 or TR2 position. To set the detector to find metals such as gold or silver, set the "Discrim" knob to Non-ferrous Metals. You can also set it to find Ferrous Metals if you want to search for iron or steel.
    • 7 Hold the detector with the search coil parallel to the ground. You can adjust the angle of the search coil by loosening the wing nut on the end of the shaft and swinging it to the desired position.
    • 8 Swing the detector in wide sweeps about 2 inches from the ground.
Read more : http://www.ehow.com/how_5011582_use-micronta-metal-detector.html
MD-3006SS Metal Detector will not tune
I had the exact same problem and after messing around with it for about half an hour I realized that the cord was the problem, I was kind of moving it around while plugged in and if I hold the end of the cord in a certain direction it works like it should. If the results are the same for you, I suggest either getting a replacement cord or just do the not so reliable option and tape the cord into place.
Can't make model #63-3006 work
Hello there: it sounds like to me you have a wire that has came loose between the power pac and the board here is a link that might help you out a little bit ok? best regards michael
Home Use - Activities - Bounty Hunter Metal Detectors Bounty Hunter allows you to download the instruction and operation manual for each machine. ... Bounty Hunter Jr. Camo-LS. Guardian. Bud Jr. Page 1. Page
2answers
A Radio Shack Metal Detector
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=63-3006&Name=Metal%20Detectors&Reuse=N
16helpful
I have a Radio Shack Metal Detector series 63-3003. It has about 6 different dials on it and I would like to know to set the dials so I can look for treasures.
Metal Detector (630-3003)
Operation:
The steps in this section explain each control on the control housing and
handle, and how to use your metal detector. Take a moment to become
familiar with the position and use of the controls before using the metal
detector.
THE VIEWMETER
The view meter is located at the top of the control housing and measures
battery power, determines the quality of hidden metal, and helps you tune
the detector.
Turning On the Detector
Hold the detector in a position comfortable for you, then turn it on by
rotating VOLUME two-thirds clockwise. Set TEST to NOR to detect.
Adjusting the Controls in the Field
The tuning skills you will learn while preparing the detector will be put
to good use during your actual search. You will know how each control
works so you can fine-tune the detector quickly.
If you wish to test the accuracy of your tuning at your current location
in the field, take a few samples of different kinds of metal with you.
Note that some metals, when left exposed to the elements, become
corroded; so, it is always wise to carry along a piece of corroded metal.
TUNING THE DETECTOR
Setting TUNE
The Radio Shack VLF Discriminator Metal Detector distinguishes between
ferrous and non-ferrous metals. When the detector senses a metallic
object, one of two reactions occurs - the sound and meter reading
increase or decrease. The result depends upon the type of metallic
material, ferrous or non-ferrous. Ferrous metals contain iron. Gold
silver, copper, platinum, aluminum, lead, zinc, etc. are examples of
non-ferrous metals.
TUNE fine-tunes the balance between the detector's receiver and
transmitter circuitry.
Follow these steps to set TUNE.
1. Rotate VOLUME two-thirds clockwise.
2. Set MODE to VLF.
3. Set TEST to NOR.
4. Set the remaining controls to mid-range.
5. Hold the search coil up in the air, press and hold down Auto-Tune,
and slowly turn TUNE. The pointer swings back and forth and the
detector sounds a tone. Turn TUNE until the pointer rests at or
near the center. Release Auto-Tune.
Note: Press Auto-Tune during operation to automatically return the
pointer to the center.
Setting MODE
Set MODE to VLF when you use GROUND (See "Setting GROUND). Set MODE to
TR1 or TR2 when you use DISCRIMINATOR (See "Setting DISCRIMINATOR)".
Using GROUND helps tune out false signals from mineralized soil.
DISCRIMINATOR distinguishes between NON-FERROUS and FERROUS objects.
Setting SENSITIVITY
To adjust the search coil's ability to detect objects at different
depths in the soil, rotate SENSITIVITY from MIN to MAX. For maximum
performance, set SENSITIVITY as high as possible. If the detector
makes a "Chattering noise, decrease SENSITIVITY until the "Chatter"
stops.
Setting GROUND
GROUND tunes out false signals from mineralized soil.
Follow these steps to set GROUND.
1. Set MODE to VLF and lower the search coil to 1/2- to 2 - inches above
the ground.
2. If the pointer swings to the left, turn GROUND to the right.
3. Raise the search coil and press Auto-Tune. The pointer returns to
the center.
4. Repeat Steps 1-3 until there is a very small variation in the meter
reading each time you lower the search coil to the ground.
Notes:
Setting GROUND takes a little time, but is critical for accurate
operation.
After you set GROUND, do not reset it until you use the detector at
a different site.
DISCRIMINATOR determines whether the hidden metal is NON-FERROUS or
FERROUS.
Before you set DISCRIMINATOR, you must set MODE. Set MODE to TR1 to
detect extreme differences in metals, such as between iron and gold. Set
MODE to TR2 to detect even greater distinction between metals.
Set DISCRIMINATOR to mid-range. While you detect, adjust DISCRIMINATOR
to the best position. The difference between iron and gold shows on the
meter (iron in the ferrous section, gold in the non-ferrous section). As
you set DISCRIMINATOR higher, the detector becomes more sensitive to the
differences between aluminum and gold, but some small pieces of valuable
jewelry, such as small rings, may be over-looked. Therefore, coin
collectors do not usually set DISCRIMINATOR higher.
Also, it first rejects small pieces of silver paper, then thick foil, and
finally metal objects like pull tabs from aluminum cans.
Notes:
Each time you use the detector, you must adjust DISCRIMINATOR. Each
expedition presents new challenges.
Press Auto-Tune during operation to automatically return the pointer
to the center.
Fine-Tuning the Controls
Set these controls:
1. TEST to NOR
2. MODE to VLF
Set the remaining controls to mid range.
When you detect metal, switch MODE between TR1 and TR2 to determine the
quality of metal. Adjust all remaining controls to their desired
positions. (See "Tuning the Detector.")
SWEEPING HINTS
Keep the search coil in a consultant parallel position to the ground
throughout the sweep. Move the search coil slowly from side to side,
covering about a 3-foot area, overlapping each sweep. The threshold tone
should peak as you pass the target center. (Hurrying will cause you to
miss targets.)
Note: The search coil will not detect without motion.
Be careful not to swing the search coil upward at the end of each sweep.
The swing up can cause the detector to emit false signals. Keep the
search coil parallel to the ground at all times but don't touch the
ground. Hitting the ground may cause a false signal.
DETECTION HINTS
No detector is 100 percent accurate. Various conditions and objects may
adversely influence metal detection. Its reaction depends on a number of
things:
The angle at which the object rests in the ground
The depth of the object
The amount of iron in the object
The size of the object
To pinpoint an object, the second time, go at right angles to the first
time, making an "X" pattern.
Note: The target will be directly below the "X" at the point of the
loudest response.
This allows you to detect some targets that were hidden the first time
due to the sweep direction. If trash in an area is so heavy that you
get false signals, slow your sweep speed and use shorter sweeps.
Notes:
A good detection has a consistent rise and drop of threshold tone.
A poor detection has irregular highs and lows in threshold tones.
If the metal is in the shape of a circle, opposite reactions may
occur.
A good target response repeats as you swing the search coil over
the suspected target. Trash-induced signals tend to not repeat.
Recently buried coins might not respond the same as coins buried
for a long period of time.
Some nails, nuts, bolts, and other iron objects (such as old bottle
caps) oxidize and create a halo effect around these objects.
A halo effect is caused by a mixture of natural elements in the ground
and the oxidization created by different metals. Because of the metal
mixtures, target signals may not be in a "fixed" position. This effect
makes these objects very hard to reject. (See "Fine Tuning the
Controls.")
TONE VARIATIONS
The threshold tone may vary slightly while you search due to soil
changes. This does not usually affect the sensitivity of the unit and
should not require further adjustment.
If the threshold tone changes significantly, you might need to readjust
GROUND. Sometimes the change in threshold tone is due to reasons other
than ground conditions and can be easily corrected by a simple procedure.
Raise the search coil one foot from the ground and push Auto-Tune.
Lower the search coil to the ground again. If this does not correct the
problem, repeat the full procedure to set GROUND. (See "Setting
GROUND.")
Apr 07, 2008 • HTC S310
Top Famous Trails Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Famous Trails Sport and Outdoor - Other Expert? Answer questions, earn points and help others
