Question about Hasbro FurReal Friends My Lovin Pup Biscuit
How do i fix furreal biscuit bent front leg - Hasbro FurReal Friends My Lovin Pup Biscuit
  • Bayard Saunders
    Bayard Saunders May 13, 2014
    I have 7 Biscuits - 3 with bent forelegs. The problem is an inadequately designed bone which will gradually bend when sitting. The straight legged ones have a slight modification at that point. I have heated the bend and straightened it, but it eventually rebent. I know of no parts supply or repair services. Hasbro is no help.
Replacement parts
Try ebay first. Or contact Hasbro direct. This is a common problem and most places usually stock spare parts. Best of luck.
Aug 31, 2013 | Hasbro FurReal Friends My Lovin Pup...
Biscuit the dog has a bent leg
You're probably going to need to remove the fur and examine the leg to see if there is a bent rod or connection joint that you can bend back out. Contact Hasbro's Customer Service for the instructions on how to remove the fur if you're not sure. They may have resources for you such as repair shops locally or in-house repair you might be able to send it for repair. if it is out of warranty, and you did not buy an extended warranty, they may charge for the service. Good luck :)
Dec 20, 2011 | Hasbro FurReal Friends My Lovin Pup...
Keeps falling over due to bent leg. Any ideas on how to fix?
Depending on which leg is bent, you should be able to move all legs so he sits properly in a sitting position on the floor. If this fails then lie him down as the legs can be moved while he is turned off.
Jun 26, 2010 | Tiger Electronics FurReal My Lovin' Pup
The dog's legs are bent inward and the head is hanging low.
Pull the legs out manually, sometimes when the dog falls over or is stores, the legs go weird. The head should fix its self when the dog is turned on.
Apr 14, 2010 | Tiger Electronics FurReal My Lovin' Pup
Biscuit the dog stopped working so put new batteries in still does not work
We bought Biscuit and the legs turned in and he just laid there so we called Hasbro and they sent us another Biscuit and he did the same thing as the first one so I called them again (Hasbro) and they said it was out of warranty and there was nothibg they could do for me so now were just out of the money we spent on it and the kids have no Biscuit to play with I DO NOT recommend this toy to be bought for any child what a disappointment it is!!!!! Thanks
Jan 02, 2010 | Tiger Electronics FurReal My Lovin' Pup
Biscuit legs seem to be out. he can not sit. His legs are criscrossed
I pulled the skin back and the legs were bent inward. They are plastic framed legs and cannot be bent back into shape. Any thoughts on where to get replacement parts for him?
Jan 01, 2010 | Tiger Electronics FurReal My Lovin' Pup
How can I safely tighten the connection with the batteries?
as long as the foil does not touch both battery terminals this will work
May 29, 2009 | Tiger Electronics FurReal My Lovin' Pup
Hasbro FurReal Friends My Lovin Pup Biscuit Logo
143 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
