Is the power coming into the system? Does the charging light lights on?
If it is the case then replace the charger.
If it is not the case charging circuit should be replaced. Small work not very costly. But if you entire motherboard is damaged by high voltage or a fluid contamination or ants going into the motherboard, then you will have to replace the motherboard.
