Question about Gemmy Holiday Light Show
Why does one half of the strand stay white and not change color or shut off using remote, other half works fine?
One half stays white will not change color or shut off using remote
Mine are doing the same thing did you get this resolved?
Posted on Dec 20, 2014
How to resolve service light staying on problem
Apparently, there is something that is not receiving power. What is the year, make and model of the vehicle?
Jun 23, 2013 | Viper SmartStart Module
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
I plugged up an Legacy LA470 300x2Ch amp. It stayed in protect mode and never changed to power mode. I checked the power and ground, works fine, then remote, works fine. I then checked the output to the...
I would suspect if the amp is known to be good, that someplace you have a shorted speaker wire... possibly someplace the insulation is cut through or maybe you have a bad connection with frayed strands shorting out the speaker. Use an ohmmeter to check the resistance between each set of speaker leads and then to ground.
Mar 26, 2011 | Car Audio & Video
The monitor worked fine when we received it several months ago. Recently it started going all white, except for a few very thin colored vertical lines. I could shut it off wait a few seconds and torn it...
If this is still under warranty, then send it back for repair. If you have connected it to 2 PCs with the same results, then the problem is internal to the monitor.
Oct 20, 2010 | Computers & Internet
RCA RT2400R Receiver shuts off 3 seconds
Try running the remote wire right to the power if it doent stay on,it may have a blown amp
Oct 27, 2009 | RCA RT2400R Receiver
Fuel light stays on 02 gsxr 1000
check for open wire on the harness going to
color/stripe
4 wires fuel pump & level wires
yellow/red,black/white are pump wires black/lightgreen,black/white
3 wires Fuel resistor module wire colors blue/Lightgreen,orange/green,red/black
o1 manual
Apr 06, 2009 | Suzuki GSX-R 1000 Motorcycles
52" Samsung DLP
It is unlikely that you can do anything yourself.
It sounds to me that there is a power supply problem that has steadily gotten worse and that cannot be confirmed remotely, it must be done on site by an equipped professional.
May 13, 2008 | Samsung DLP HL-P5663W 56" TV
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
Gemmy Holiday Light Show Logo
143 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
