Question about Refrigerators
Whirlpool et18pkxgto Seems to run more than usual (does stop periodically). Now finding water on top shelf at back of refrig once a day. No setting below normal for freezer; have it set on 2 out of 5 options for fridge. No power saver option, either
  • 833 Answers
SOURCE: Leaking water INTO fridge
Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
Posted on Jan 22, 2008
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
mgprice
  • 744 Answers
SOURCE: My fridge has water pooling on the top shelf
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 14, 2009
Testimonial: "This gave us an idea of what to do. The drain tube was blocked with some plastic lumps that must have come from the factory in our 3 month old fridge."
arikrom
  • 528 Answers
SOURCE: Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Posted on Jan 02, 2010
Water is dripping from the top of the refrigator onto the top shelf. We defrosted the freezer; no change
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Whirlpool ET1RHMXKQ Top Freezer...
Water leaking in from freezer into main refrig at the back
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jul 05, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
The water is overflowing from the freezer onto refrig shelf
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
Sep 26, 2009 | GE Profile Arctica Stainless Steel Top...
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Leaking whirlpool fridge freezer ARG752WBM37 from freezer into fridge
That water is coming from you defrost cycle. Your defrost drain is plugged up with either ice, or possibly food, trash etc. Remove the back wall in the freezer....it is only a few screws. If you have an icemaker pull that out too, should be 3 screws usually. Pull that back wall and in the bottom beneath the coil you will probably see ice, or possibly a pool of water. Defrost that ice or chip it out with a screwdriver. Be carefull because the little drain pan in there is lightweight. You might want to use a hair dryer for this but it takes a little while. I usually just put hot water on it, but put a big bowl on the top shelf of the refrig to catch the water. After you melt it find the drain hole and flush it out. I usually run a peice of wire in it to unclog it. after you unclog it pour a cup of water down it to flush it out.
Sep 08, 2009 | Refrigerators
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
The refrig is Model ET8HKXM003 and Serial # E54044751 Manufactured 10/05. It is type 18TFA. The Temp is currently set on 3 (normal). The freezer appears to be leaking down into the refrig as I find...
the drain tube on the machine has frozen in the freezer section
remove the back panel and with a hair dryer thaw the drain tube
you will see an alluminum sheild with a 1/2 inch hole in the bottom of the shield this is where you want to direct the heat
it may take 20-30- mins to unfreeze it to make sure it is unfrozen pour som water into the valley of the sheild if it runs into the drain pan it is unthawed if it pools up keep unthawing
Apr 16, 2008 | Refrigerators
Loud banging noise and water leaking
not much can be done about compressore noise, short of replacing it. but your drain issue is easily fixed, with that whirlpool heat strap you mentioned.it actually wraps around the heater in frezer section and the idea is that when the unit goes into a defrost cycle(3 or 4 times a day) the heater heats the strap(which runs into drain tube) up as well, preventing tube from freeezing up and eventually backing up into your freezer floor
Feb 23, 2008 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
