Question about Plumbing
Arcylic shower base installed backwards
I am in the middle of a major bathroom install and have installed a 32 x 40 Uberhauss Shower base. I have glued in the drain, cement board and tiled the walls and tiled the floor. I am about to install the glass sides and realized the plumber (with me helping) installed the shower base facing the wrong way. The water flange that should be under the door is under the tile, and the flange that is under the door is 5/8" too high. I can't be the first person to do this - can I? Thoughts - can a belt sander be used to lower the lip to the correct height? Any other solutions?
    Genius:
  • 1,406 Answers
If it were mine... I'd kick myself several times (yeah, I've done stuff like that), then bring in a 4" angle grinder with a cutoff wheel. That would cut the flange MUCH faster - and generate far fewer sparks - than a belt sander. Work really carefully, though, and maintain really close control so the angle grinder absolutely stays level while you work. In fact, this would be a good spot to make up a special little jig to keep the angle grinder level and supported at one uniform height all the way across the door.
Posted on Jul 26, 2014
2 Suggested Answers
  • 1015 Answers
SOURCE: i bought a maax shower
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Posted on Jan 30, 2011
Im fitting a show tray in an en suite the stair way comes up underneath so if I fit the shower tray to the wall about 3" of the tray will poke through the plaster board showing above the stairs.
Hi Chris:
Sounds like you've identified the two logical choices.
It may be preferable to raise the shower for at least 3 reasons:
1) Headroom and aesthetics of the stairway ceiling will not be affected.
2) The installation of the shower drain trap will have more space available.
3) It will be easier to provide structural support for the shower base.
Hope this helps.
Cheers
Apr 05, 2016 | Home
Need to remove silicone from 4 part shower stall to repair & reinstall
I think you should contact to a professional who can remove this shower stall very easily without any risk. You can also have a look at shower enclosures for having such bathroom stuffs in affordable price.
Jul 14, 2012 | Home
How to add a shower to bathroom
have to open wall , other side of shower if sheet rock is better, replace faucet controls, add new pipe up and install shower head then re close wall.
May 14, 2012 | Home
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
When the builder installed the single handle shower faucet in one of my spare bathrooms, the handle will go from off to the middle (warm), but will not turn any farther towards hot... how can I fix this,...
With some installations there is a setting screw to prevent the tap going all the way hot in an effort to prevent scalding to the elderly or children while in the tub/shower. You may have to take off the handle, and ring to check and see if this is the case, if so, a small adjustment to the screw inside will allow you to go beyond the current setting.
Please let me know if this helps and include feedback.
Mar 15, 2011 | Delta & Single Handle Shower Faucet
Shower drain still leaking
Shower drains can be a real pain to install. If you have the screw in type with the rubber gasket and card then you need to take it appart again. The card usually rips and then the rubber is twisted out of place. Use clear bathroom silicone (not acrillic based) between the upper grill part and the shower base, lube the plascit nut & rubber with silicone grease (home depot) and throw the card (now crushed or soaked) in the garbage. Have someone hold the grill in place (needle nose pliers) while you put the rubber & nut on. Keep a close eye on the rubber as it can still get forced out as you tighten. Clean up the silicone before it sets. If you have the rubber wedge style then I would suggest that you buy a screw on type.
Mar 07, 2010 | Plumbing
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
My shower drain gurgles when the washing machine drains
The drain from your washer is tied to your shower drain and it is receiving air from your shower drain. Maybe your washer drain is not vented. This should not be a major concern if you can live with the noise.
Jan 03, 2010 | Dryers
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Plumbing Logo
131 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
