Question about DeLonghi P90D23EL-B1A Easi-Tronic Solo Black Countertop Microwave 23 l, 900 Watts
Mircowave works but doesn't work for heat/grill defrost etc
What might be the problem???
  • 1 more comment
  • MARWAT
    MARWAT May 11, 2014
    Hi Demi bishop, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?thn how you can say that its working plz explain
  • Demi bishop
    Demi bishop May 11, 2014
    When I say it's working I mean it works but doesn't heat anything up or defrost the light is on.
  • Demi bishop
    As you start you mircowave off for 30 seconds it use to warm or anything now it's just cold air.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
1.check fuse
2.check relay (microwave oven magnetron)
3, check switches of the doors
Mircowave works but doesn't work for heat/grill de - 90ccffd3-b73b-4106-b181-24faf99473d0.jpg
Posted on May 11, 2014
My de longhi ac925chs has suddenly stopped heating or defrosting but making all the right noises. The oven and grill still work ok. Is this just the fuse and if so, can i change it myself?
It's most likely a burned magnetron, and it's usually as expencive to replace than a new oven but since yours is equiped with a grill and conventional oven check the prices it could be worth changing...
Aug 03, 2011 | DeLonghi MW 535 Microwave Oven
GE spacemaker mircowave not heating- all else works ok
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
I have a samsung 1000 watt mircowave that appears to be working in every way except that it is not heating the food at all. It is 2 years old.
There is two posibilities, iether the transformer, is not working or the magnatron, there are very expensive, if all the functions are working then there should be an errror code on display
Jan 06, 2010 | Samsung MW1030WA Microwave Oven
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Mircowave will not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
DeLonghi P90D23EL-B1A Easi-Tronic Solo Black Countertop Microwave 23 l, 900 Watts Logo
117 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
