Question about Xerox Phaser 6250 Laser Printer
What xerox phaser 6250B error ram - Xerox Phaser 6250 Laser Printer
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: Phaser 6250 "Ram error" (?)
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Posted on Apr 15, 2008
  • 2072 Answers
SOURCE: XEROX 8550 DP ERROR Message 09,035,43; 10192
That is a cyan, ( blue) ink stick fault. What is happening is that the cyan ink sticks are not advancing down the ink loader properly.
Open the area where you load the ink and you probably have a cracked, twisted or otherwise stuck ink stick, the code you are reporting specifically refers to the cyan sticks. If you have to remove them, take a screw, a drywall screw is best, and twist it into the sticks and slide it back and out, then replace them or add new ones. But thats your problem.
Posted on Oct 29, 2008
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
  • 111 Answers
SOURCE: Our Xerox Phaser 4510 has
You are going to need service. It is memory on the main board that is giving you the error. Unfortunately it probably won't be cheap. Either the RAM or the motherboard has gone bad, but there is no way to tell until you have it checked. I have seen several people try this and then try that for weeks, then finally have to break down and get it serviced. Save your self the headache and have a trained professional solve your problem.
Posted on Nov 18, 2010
I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
Display shows RAM ERROR on Xerox Phaser 8860
I would first try to inspect and possibly replace the ram. On the back of the machine there are two thumb screws holding on a metal plate. Remove the two screws to access the ram. You can remove the ram and try the second ram slot if it is unused. (check the video at 2:45 to see what this looks like) If after replacing the ram and trying both ram slots the error continues you most likely need to replace the Electronics module (MFP part# 084K36560, non-mfp part# 084K36550). Here is a video that shows you how to replace that part. (video is of a 8500 non-mfp version so it is a little different but still similar). Good luck, and thanks for using FixYa!
Sep 01, 2011 | Xerox Phaser 8860MFP/D - Multifunction -...
Ram error
Reseat the RAM in the slot, if the same error occurs replace the RAM. To order options for your Phaser 4510 Laser Printer, contact your local reseller or go to www.xerox.com/office/4510supplies
Feb 07, 2011 | Xerox Phaser 4500 Printer
Our Xerox Phaser 4510 has a RAM ERROR. Tried cutting machine off overnight but still has same error.
Nov 18, 2010 | Xerox Phaser 4500 Printer
Phaser 7760 - RAM ERROR
yes often your printer Ram or reset then solve it
Jun 25, 2009 | Xerox Phaser 7760DN Laser Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
Ram Error message
Have you tried reseating the ram?
Dec 13, 2007 | Xerox Phaser 7700 Laser Printer
Open Questions:
Xerox Phaser  6250 Laser Printer Logo
19 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
