Question about Exercise & Fitness
Pro fitness pcb manual
Photo or outlay
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 141 Answers
Search and download but it's easy if you right .pdf or .ppt like that..
Posted on May 11, 2014
The same control PCB is used for the refrigerator and freezer, but the setting of the PCB is 1 if fitted in a freezer and 0 if fitted in a refrigerator. Does anybody know how to change this setting?
Look for a jumper much like the kind you find on Hard drives and computer motherboards. If there is one. there will be indicators printed on the board.
Jun 17, 2015 | Turbo Air M3R47-2 Reach-In Refrigerator
Error E 732 0001
E732-0001 Error Code: Reader Controller PCB is faulty
[ Case in the field ]
Description
E732-0001 can be displayed when a communication error occurs.
Cause
In the field, this symptom occurred because the Reader Controller PCB was faulty.
Field Remedy
1. Make sure that the connector between the host machine and the reader unit is securely fitted.
2. Make sure that the connectors on the Reader Controller PCB are securely fitted or there is no pinched cables.
3. Remove and insert the Main Controller PCB (Sub) from the Main Controller PCB (Main). If the symptom still recurs, go to the Step 4.
4. Replace the Reader Controller PCB with a new one.
E732-0001 Error Code: locks up during copying
E732-0001 can be displayed when a reader communication error occurs.
Cause
As a result of inspection, it was found that this symptom occurred because of poor soldering of J1302-34pin on the Main Controller PCB (Sub).
Field Remedy
1. Make sure that the connectors are securely fitted between J1302 on the Main Controller PCB (Sub) and J502 on the Reader Controller PCB and that
there is no pinched cable.
2. If no problem is found, replace the Main Controller PCB (Sub) with a new one.
E732-0001 Error Code: Because of poor contact of SDRAM
Description
E732-0001 indicates that a reader communication error has occurred.
Field Remedy
As a result of inspection, it was found that this symptom occurred because the SDRAM was not securely fitted on the Main Controller PCB. So, remove
and insert the SDRAM once again.
Sep 26, 2013 | Canon imageRUNNER C3200 Copier
Canon iPF 8300: Hardware Error 2F48
Canon have a Technical Bulletin regarding this error (TP11 3337d.pdf). In my experience it starts with E161-403F/E and if you get past this in Service Mode it cannot detect the paper size (the multi-sensor lights on the carriage do not work). After re-seating the flex into the PCB I got the 2F48 error. I think it is related to poor ink flow at some point.
The bulletin recommends (after updating firmware) you:
-Turn printer off
-Remove both heads and dispose of them (Can carriage EEPROM corrupt new heads? $1000 in the bin?) - bulletin states heads MUST NOT BE REUSED so seems like they mean it.
- Replace Carriage PCB - another cost!
- Turn on in Service Mode - WITHOUT HEADS INSTALLED YET
- Turn off (clears errors)
- Turn on in User Mode and install heads as normal
- Check ink is flowing into heads - if not you may well fry another head so you need to get hold of a Syringe Kit to pull it through manually (don't ask me how!)
The bulletin also then - disgracefully I add - goes on to say that if this doesn't work change the Main PCB as if the $2000 outlay to do so was an arbitrary amount of money to pay to get the clearly mal-designed printer to work again!
Good luck anyone reading this, I'm about to do this myself today on my Canon iPF8300S - but before I hook out the Carriage Relay PCB and heads I'm going to connect a new flex from Main PCB to Carriage PCB and hold it in the air while the printer initializes (chasing it through the machine is a ballache if not required). The crushing of the flex by the chain/against plastic mount is far too common - and a known issue since ipf8000 at least and definitely worth a try if more than one head error occurs.
Aug 30, 2013 | Canon Office Equipment & Supplies
The data subscription is ridiculous. Why do we have to pay for a device we already paid for? Chalk another one up for pinching the customer.
The data subscription provides you with analysis for the metrics that the BodyMedia Fit Link provides. Although a monthly fee can be a pain, it\'s actually a pretty legit service.
Check out Costco or online to see if you can purchase a cheaper version of the subscription. For sure will be in bulk so your outlay will be bigger at the start, but it will save you coin in the long run.
Aug 06, 2013 | BodyMedia Fit BluTooth FIT LINK Armband
I have canon c2620n and when i turn it on give E 732-0001 i need help pleas
Description
Cause
Field Remedy
Cause
Field Remedy
Description
Field Remedy
Jan 31, 2011 | Canon imageRUNNER C3200 Copier
I am looking for Internal diagram - Service Manual for Sansui TV
I AM LOOKING FOR A CIRCUIT DIAGRAM OF A TV MODEL E2999 .THE COMPLETE BOARD OUTLAY AND DIAGRAM
Apr 08, 2009 | Televison & Video
Photo card doesn't fit slots
You need a Memory Stick pro adapter or copy contents to a SD Card
Jan 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Cluster PCB
sorry i don't have a photo yet, but what i did was remove a small section of the laquer from the track on the PCB about 1/2 inch away from the plug socket, then pre-tinned & soldered a small insulated wire (small speaker wire, only 1 part of the figure 8 cable) from the bottom right plug track (common pos for the warning lights) to the solder joint @ the lower end of the under PCB link that goes to the bottom left screw fitting of the tacho, this bypassed the crack in the PCB,
if there is "NO" burn marks & it is only a cracked track you will-not have any problem in bypassing the crack with a small wire, or even running a small solder track along the PCB track, just remember to remove the laquer, kind regards waz
Nov 27, 2008 | 2002 Mitsubishi Lancer
Main cooling fan switches on and off rapidly
hi there,
could i get the exact model # for your stove please?
Sep 14, 2008 | Tecnik Ovens
Exercise & Fitness Logo
32 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
