https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/75-150-hp/Mercury FourStroke outboard motors are incredibly powerful and efficient, and they feature a wide range of applications. Crafted for less weight and high displacement, they generate abundant torque and immediate power. ... 150 115 90 75.
HP / kW: 150 / 110 Engine type: 8-valve single overhead cam ... Dry weight *Lightest model available: 455 lbs / .
? 2:29 www.youtube.com/watch?v=sMmionreldM Dec 29, 2012 - Uploaded by Peter Richards
Engines for 1989 Larson boat with dual 115 Yamaha 4 StrokeEngines. ... Outboard Yamaha 150 HP DIRTY idle JETS, Motor will not idle .
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster. I would appreciate any feedback on this problem.
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
