Question about Exercise & Fitness
How to change the tension on a pro fitness rowing machine
How do i change the tension on a pro fitness dual hydraulic rowing machine
3 Suggested Answers
  • 133 Answers
SOURCE: right hydraulic cylinder that supplies
If you are referring to the hydraulic ram that provides tension to an ore, there is nothing to do but replace it. If the ram side can be unscrewed from the body, it can be rebuilt. There is a plate attached to the ram (shaft or coupling) with a small orifice drilled in it. A spring is normally used to hold the ram in its normal position. The cylinder is filled with hydraulic fluid (usually a light oil). When pressure is applied, the fluid is forced through the orifice as the ram is compressed and slows its movement while absorbing any shock. When the pressure is removed, the spring returns the ram to its original position. The spring (?) is most likely broken if the ram did not return to its original position. If it remains collapsed, there will be no tension. If the ram can not be removed to access the return mechanism, the whole assembly will need to be replaced. I had to guess a little on your exact situation and may have missed here. Please don't hit me too hard if so. If this is off, please give me a more detailed report to work with, OK? Thank you for using FixYa. Roger
Posted on Apr 22, 2011
  • 21 Answers
SOURCE: instuction maual fitness pro rowing machine
just row, row, row
Posted on Dec 02, 2012
How do I adjust tension on a Pro Fitness Dual Hydraulic rower?
move the cylinder attachment higher on the arms .
May 03, 2016 | Exercise & Fitness
Can you reuse a hydralic tensioner adjuster? also how to tell tdc on 2.4 dual oh cam
hydraulic tensions are best replaced with the belt or chain. They do a lot of work and can leak and if it is a belt then that will cause early failure of the belt
Mar 25, 2015 | Cars & Trucks
Do you have to replace the hydraulic timing tensioner adjuster after pin is pulled and installed or can it be reused?
Hi Steve, I'm AL the owner of Big As Auto Repair in St Charles Mo
Steve, the pin style hydraulic tensioners can be reused by pushing the tensioner in with a press and installing a pin to hold it. HOWEVER, I replace the tensioner to be safe if the engine has 100,000 or more miles on it. I do that because its an interference engine, meaning you can bend the valves in the head should the tensioner not do its job because of age and miles. For further assistance click here: Auto Repair
Mar 25, 2015 | 1998 Dodge Caravan
How do i repair the hydraulic unit it leaking oil on my 2010 bh rowing machine
What exactly are we looking for here A farm tractor perhaps never saaw a rowing machine with hydraulics before
Jan 26, 2015 | Washing Machines
Tension Problems
have to ask --are you sure that it is a tension problem
could be a needle /hook timing problem because if that is off it will also miss stitches
it can be off from worn parts and bushes
Mar 27, 2017 | Sewing Machines
Precor rowing 612
any hardware store should have that wingnut..
Jan 15, 2014 | Exercise & Fitness
Tension on magnetic rowing machine
magnets get stronger the closer they are to the metal
undo the tension knob all the way out
it may be broken off the magnet in which case it will always be close to the metal
Apr 18, 2017 | Exercise & Fitness
Is there a noticeable difference in performance between hydraulic, air and magnetic rowing machines?
yeah there is usually the the size and price and how realistic the rowing action is, but they all work the same areas and burn lots of caories, its just depends how realistic a row you want, how much money you have to buy one and how big your workout space is to put the thing
Dec 01, 2008 | Kettler Rowing Machine Kadett Rowing...
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
