M PSA10A-OY75MP SAT A10 SYT UNI CORRECT BATTERY MOD NO PA3284U-1BAS ?because battery says 10-8v 3600mAh charge pack says 15v~5a
  • 41 Answers
I didn't understand fully but it is not unusual for a laptop battery to have a different voltage to the charger. My laptop battery says 11.1V 56Wh but my charger says 19.5V @ 4.62A. As long as you have the correct battery replacement part and correct charger everything will be fine.
Posted on May 11, 2014
2 Suggested Answers
  • 375 Answers
SOURCE: Charge time for new Li-ion battery pack
4,5hours.
Posted on Jan 27, 2010
1995 jeep not charging battery
dash lamp on,, tell you that or?
bad battery (or cables to same.)
bad wires. to alt.
bad alt.
belt fell off
belt is not set to correct spec.tension.
(illegal mods. or wrong alt in car. old cars have this, 95 is old)
there are simple tools to check this.
running engine RPM, 800 minimum. is it.
battery volts 13.3 to 15v. is good , less is bad.
Jan 06, 2014 | 1995 Jeep Grand Cherokee
I want to update the bios on toshiba satellite a10
Go to Toshiba support website and enter your computer model no. to get new driver, there may be a Re flash of Bios available.
Oct 10, 2012 | Toshiba Satellite A10-S100...
Error code orange light flashes toshiba a10
This indicates a motherboard issue, I would suggest a professional at this point to access if it can be fixed at a realistic cost.
Mar 08, 2012 | Computers & Internet
When I go to use wi-fi, it keeps saying wi-fi is disabled. Yet, other laptops in the house work off the wi-fi
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Aug 01, 2011 | Acer Tablets & eReaders
When I put my adapter inside for charge my laptop turns off and the light is on saying that is charging but its doing nothing pls help. Regards
Read the article below, may it will help.
Laptop shuts off when AC adapter plugged in
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Jan 09, 2011 | Toshiba Tecra M5-384 Laptop AC Power...
Cant charge battery pack for wii fit balance board
You may want to send an email to customer.services@gem.co.uk. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
Jan 27, 2009 | Nintendo Rechargeable Battery Pack 3600mAH...
Turning on problems..
Is the power source a 15v 5a or a 15v 8A? You more than likely have a Dead system board. The blinking amber AC power led usually means a power failure due to improper voltage or amperage.
More than likely caused by a 3rd party (non-Toshiba) adapter.
Sorry for the bad news. :(
Paeasop
Apr 10, 2008 | Toshiba Satellite A25-S207 Notebook
Computers & Internet Logo
David Payne
David Payne
