The speakers on the left side of my jukebox are not working
    Champion:
    Habit-Forming:
  • 239 Answers
Amplifier problem or speaker wires loose.
Try swapping speaker wires.
Posted on Aug 09, 2014
2 Suggested Answers
barnes07
  • 16 Answers
SOURCE: NSM Digital Thunder CD Jukebox speakers on right side do not have sound
make sure speaker wires are all pluged in. if that dont wort check the speaker wire it my be broke in between speaker and player, try new wire
Posted on Jul 16, 2012
I have a Rowe AMI 100 cd jukebox. The right side speaker will play for about 3 songs and then go out. Other speakers continue ti work. Is this a speaker problem or something else?
Make sure all the wiring is secure, you may have a bad coil on the speaker, then you need your amplifier checking by someone competent
May 01, 2014 | Wurlitzer Jukebox CD Player
I have a Rowe AMI 100 CD jukebox. It plays about 3 song and then right upper speaker goes out. Is this a speaker problem or something else?
You could have connector problems on the speaker crossover network located inside the amplifier compartment on the opposite wall from the amplifier. Typically the solder joints go bad where the connectors are soldered to the board. Usually a simple resoldering can fix it. There could also be problems with the connectors at that particular speaker itself.
Jul 16, 2012 | Audio Players & Recorders
My nsm jukebox has error#73 . What is that? why wont it play?
malfunction of left side magazine check alignment and grip function
Oct 07, 2011 | Wurlitzer Jukebox CD Player
Can auxiliary speakers be added to a Rowe/AMI Model CD 100K? If so, where do they connect?
Yes they can. Above the amplifier compartment you should see the output package. The output package is where the phono speakers are connected to but this can be used to provide output to extention speakers. E1 to E7 tappings left and right provide outputs at different voltages/wattage. E1 left and right is the comon (or ground connection) E2 is the lowest tapping and E7 is the highest. Most people would connect extention speakers to E3 or E4 left & right with the comon connections of the speakers to one of the E1's.
There is also connections for 70 volt line speakers, these are used where long cable runs are needed and the speakers are then fitted with 70 volt drop down transformers to the correct wattage of the speakers. These are available from most good electroic suppliers such as R.S. or Maplins etc.
Regards
Alan Hood
ami-man
Uk
Oct 07, 2010 | Vintage Jukebox External Speakers Shelf...
Want to conect external speakers.to 1015 amplifier need to know what plugs-jacks to buy each left -right outlet has tiny rectangular connection .and tiny hole size of pen nib.thanks jay
On the K99 amp there are just 4 screw terminals on the left side of the amp. So you just unscrew the screw a little and clamp the speaker wire under it. What you are describing though is different. (Are they on the speakers?) The edge of the rectangular bit presses down, then you push the bare end of the wire into the hole and release the plastic part. The wire is then clamped inside that little hole.
Apr 16, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a rockola mystic jukebox & one side of the speakers does not work, i would be greatful for any tips
Either a bad connection somewhere, or one channel in your amplifier is out.
Before you try anything else, switch the amp from 'stereo' to 'mono.' If the speakers come on, your amp is good and you simply have a bad connection somewhere between the amplifier and cartridge (thing that holds the stylus"needle"). Or, possible, but not probable, a bad cartridge.
For a quick fix, switch the amplifier to "mono" and then run all the speakers to the working channel.
In the meantime, if you're handy, try switching the speaker leads and such and see if you can isolate the problem.
Kyle~
Apr 18, 2009 | Vintage Jukebox External Speakers Shelf...
Can't connect speakers to my Jukebox 2000
If you are talking about a NSM Juke 2000 there is a hole in the top left corner of the back of the cabinet for the wire to come in. Just to the left of that hole on the edge of the circuit board at the top there should be a grey strip with six screws in it. The speakers attached to (from the top) 1 & 3 and 4 & 6. You need to play with them to get the polarity right or the speakers will be out of phase.
Apr 02, 2009 | Audio Players & Recorders
Outside speakers
The two volume controls only work independently when you set the jukebox to 2 channel and mono. One controls the jukebox, the other controls the speakers. There are 3 switches to change on the amp before it will work.
Dave F.
Jul 28, 2008 | Wurlitzer Jukebox 1015 One More Time...
How the heck do i download my cd's to this darn MP3 player ???????????????
I hope you have Windows XP. Download Musicmatch Jukebox (google it). Open up Musicmatch Jukebox and on the left hand side is a link to download songs to the MP3 player. Click on the link and follow the directions. Musicmatch Jukebox does not work on Windows Vista (yet).
Nov 05, 2007 | RCA RD1076 MP3 Player
32 people viewed this question
 Grubhead
Grubhead
