Question about HP PHOTOSMART 7520 E-ALL-IN-ONE
Factory reset 7520 - HP PHOTOSMART 7520 E-ALL-IN-ONE
How do i reset my computer to factory settings
on start up keep pressing F10 it should ask you what you want to do from a list it will give you.
Jul 26, 2016 | Acer Extensa 5210 5220 5620G 5620Z...
Hi can u tell me how i can reboot my aspire 7520 back to factor reset
why you need to restore to factory reset.? you can change your OS to win XP, win vista or win7. But if you still need to restore to its factory reset you need to run restore either from bios or from boot menu.
Jan 14, 2011 | Acer Computers & Internet
How do i reset my Acer Aspire 7520 to factory settings with out using the cd
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
note that you will lose any personal settings that you have made by doing this
hope this helps
Nov 10, 2010 | Computers & Internet
Acer aspire 7520 cant connect to LAN ( local only)
Hardwired to modem or router?
Router = check connection to router
(had a router die on me last fall - not AC supply)
IP should be 192.168.1.xx or 192.168.2.xx
(is standard)
Reset Router = reset hole on back - hold for 10 sec
Modem= same directions as router
(most modems work like single port routers)
(do reset of cable modem, I've had that prob too)
Using PPOE connection = check log on info
Took most of my home network apart to find it was the modem causing the problem - should've started there.
Apr 04, 2010 | Acer Aspire 7520-5185 Laptop
Toshiba 52HM95 whirring noise
Color wheel. Not replacable on this set. Removing light engine and having rebuilt is only solution. Part no longer available.
Nov 17, 2009 | Toshiba 52HM95 52" HDTV Projection...
FORGOT PERSONAL CODE
ok you take off the back battery cover when you have done this push and hold the power off button while still pushing down the power off button remove the battery and put it back while still holding the button the phone will then reboot when you see the palm icon come on the screen let go or the power off button. this will reset the ph back to it factory settings ie (reboot).
nothing will be wiped from memory stick.
Aug 02, 2008 | RIM BlackBerry 7520 Handheld
Aspire 7520-5071 lost hard drive space
WHEN YOU RESET YOU INSTALLED IT OVER A PARTION THAT WAS NOT BLANK, THIS MEANS THAT ALL THE DATA THAT WAS ON THE HARDDRIVE BEFORE IS STILL ON IT AND YOU DID NOT CLEAR IT YOU WILL NEED TO DO A FACTORY RESET BUT FIRST REFORMAT YOUR HARDDRIVE, OR DELETE THE PARTION...
Feb 21, 2008 | Acer Aspire 3690-2196 Notebook
HP PHOTOSMART 7520 E-ALL-IN-ONE Logo
Seeker5211
Seeker5211
