Question about JVSG CCTV Design Tool
JVSG CCTV Design Tool - JVSG CCTV Design Tool
I want to reset my h 264 dvr but the remote stop working only the logo screen comes up
CCTV & Networking Technical Support
1. Connect Your DVR to Network.
2. Press Window Key + R in Your PC and Type "ping -t (DVRIPADDRESS)" if it is giving reply then you are ready to process next step.
3. You need to access your dvr with telnet port (23)
for that download tool "Putty" Link: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
4. Open Putty Tool and input dvr ip and port 23 (telnet)
click connect login username: admin password: xc3511
if success then email me on nitinplus@gmail.com
I will help you to reset your DVR.
Visit:- CCTV Networking Technical Support
Nov 28, 2017 | The Home Security
Hi there a friend of ours installed our dvr modelH264 he has forgotten the paasword any help in resetting this would be great
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
YALE PREMIUM HD720 CCTV DVR
Contact the manufacturer to see if there is a way to reset the account.
Nov 29, 2015 | AccessData Password Recovery Tool Kit (ftk...
Circuit diagram for Reyed RYD180-A01 12VDC 18 Output switch mode cctv power supply
I know the rating is under but most CCTV does not pull the full power.
The only method to confirm the CCTV is to connect you DDM in series in AMP scale and see what it use.
Jan 05, 2014 | AMP Fuse Cctv Dvr Power Supply Box
Cctv
Use Free DDNS Services
Create Free account.
Visit:- https://www.noip.com/ CCTV Networking Technical Support
Dec 25, 2013 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
Serial number
Contact software manufacturer or distributor and they will assist you
May 02, 2013 | JVSG CCTV Design Tool
Computers & Internet Logo
Top JVSG Computers & Internet Experts
David Payne
David Payne
Are you a JVSG Computer and Internet Expert? Answer questions, earn points and help others
