Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Pioneer djm 600 no power
Playing at a club last night and suddenly there was a crackling sound from the mixer and then it stopped working completely, checked plug fuse & internal fuses, they are ok, main transformer still working, can hear the hum of it, but nothing lighting up...
  • 4 Answers
SOURCE: pioneer djm-600
the rcas need to be resoldered
Posted on Nov 03, 2007
marsrover
  • 682 Answers
SOURCE: My DJM-400 has died on
yes look inside in power line(after you disconnect power cord)from outlet.for fuse befor power transformer.
Posted on Aug 22, 2008
SOURCE: my pioneer djm 600 mixer
replace the whole heaphone jack!! Replace it with a new metal 1/4 in. 3 piont jack that you find at any radio shack for a couple bux(these are also the same type of metal 1/4 in jack you'd find on an Allen&Heath brand mixer). The factory one on pioneers is a cheap plastic (Sony ,I believe) peices of **** ,and they always go out or brake. It's not hard to do it yurself though. As long as you can solder and have some apptitude for basic electronix ,you can do it yurself. You'll have to remove all the plastic knobs. then remove the 6 screws on the top plate; the four corners and the sides from the top panel. Don't forget the 2 on the outside of the crossfader ,and the 2 at the top for the mic xlr plug in. Then the top panel/plate should come off easily. This should expose the heaphone jack and enable you to remove it. There's a cheap plastic nut holding the jack on ,remove that and gently pull out the headphone jack till the wire slack catches. cut/snip the wires as close to the headphone jack as possible ,noting their placement! Remove sum jacketing from the ends of the wires ,and solder them back into place on the new metal heaphone jack make shure to test the jack out before putting everything back together!!. Follow the forehand instructions backwards and wahlah. You'll probly never have to replace the headphone jack for the rest of the life of the mixer. I've had the same 500 for 5 years now. The headphone jack went out on it in the first 6 months I had it. I replaced it my self and its werked fine and minorly trouble free for years past. I had to retighten the top nuts once or twice over the years ,but no biggy. Hope this helps! good luck
Posted on Oct 25, 2008
djproaudio
  • 515 Answers
SOURCE: Pioneer DJM-600 black Professional DJ power on but not working!!
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
SOURCE: i have my pioneer djm 600 for about 5 years. I
You've got dirty pots mate! You need to clean all the dust and **** from inside the sliders and the circular trims. The plastic shaft ALPS pots in the DJM600 don't have a sealing bush so if you pull the knob off and spray some "no-residue contact cleaner" down the shaft you may get it to the bottom. DO NOT use WD40 as that leaves an oil and will clog the pots (as the oil will eventually mix with new dust and make a gloopy paste) This would then break the sweeper contact with the resistive surface.
Virtually all the ALPS pots on the 600 are stereo so as you have lost a channel some of your pots have lost connection already. Cleaning may help but if not you may need to strip down desolder the troublesome ones and replace (or if your feeling brave bend open the tabs and clean internally)
Don't worry though. I got the right cleaner (electronic use no-residue stuff) from a car accessory shop and it all started working again without opening her up.
Posted on Mar 20, 2009
PROBLEM WITH THE AUDIO OUT CHANNEL
It sounds like you may have a bad cable. The most common place for a small gauge cable (such as RCA, TPS, XLR, etc) with metal connectors to fail is in the stain relief which often fails to live up to its name. An easy way to check this is to grab the cable near the connector and wiggle it. If the sound crackles and changes volume levels suddenly then you may want to try a replacement cable. If the replacement doesn't help, you should use a contact cleaner such as "Blue Shower 2" that is approved for electronics use. Make sure your mixer is switched off and disconnected from its power source before using any cleaners to avoid any risk of electric shock. Apply the cleaner to all exposed output connectors on the mixer. Hope this cleans up your output prolems
Jan 19, 2010 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 . NO POWER.
I have the same problem, One day I open the djm-600 for replace the jack whole (easy), then of this when i close the mixer my pioneer died, but when I push the power button I can listen a little sound like ¿voltage running? Please Help !!!
Thanks
pd: sorry for my bad english
Nov 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600 - fader panel not working
i would recommend checking a fuse somthing with such good quality would less liky need a replace ment unless the power cut really damaged it internily
Oct 06, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
A DJ Pro Audio Co.
Oct 02, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
- OPTiC
A DJ Pro Audio Co.
Sep 23, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pionner efx 500
send out from mixer---------to pioneer in---------from pioneer out-----to return in mixer.
May 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
46 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
