Question about Kyocera TASKalfa 180 Copier
JAM J21 ERROR CODE IN TASKLFA 180 ?? - Kyocera TASKalfa 180 Copier
Kyocera TASKalfa 180 Grayscale Copier J21 error
clean or replace the rollers for the cassette or check behind the cassette for paper
Jan 12, 2017 | Kyocera Office Equipment & Supplies
Error J21 on taskalfa 180
try taking out the cassette and cleaning the pick up feed rollers with isopropyl alcohol. jam 21 is no paper pick up from cassette.
if this does not work my need new feed rollers or feed clutch
Mar 26, 2014 | Kyocera TASKalfa 180 Copier
Kyocera Mita TASKalfa 180 error code j41
Check that the registration switch lever does not jam inside the guide by pushing on it. You may have to modify the grooves that the lever shaft rides in to allow it to swing freely.
Jul 01, 2012 | Kyocera Mita TASKalfa 180 Black Toner...
J21 code on a Kyocera KM 3035
Multiple sheets in paper feed section (jam code 21) Feed switch 3 (FSW3) of the copier and the desk feed switch (DFSW) do not turn off within the time required to convey the length of the used paper size plus 635 ms of turning on.
Elektrotanya for electronics experts
Service manual attached.
May 15, 2012 | Kyocera Office Equipment & Supplies
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Kyocera TASKalfa 180 Copier Logo
79 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
