Question about Dell Latitude C640 Notebook
I have problem with my dell latitude d800 modular bay cannot identified
  • 9 Answers
SOURCE: Dell Latitude D800 Processor slows down
This is the SpeedStep technology feature of your processor. It will speed back up to 1.7 GHz when it is needed. Slowing down the processor saves battery life.
Posted on Jan 02, 2008
Geekman
  • 32281 Answers
SOURCE: Dell Latitude D800 Boot Problem
Did the diagnostics pass the RAM and the hard drive.
You should check the BIOS settings to see if the hard disk is detected, if possible reset the BIOS back to the default settings and see if the computer boots up.
If not :-
Then it appears that the operating system is either corrupted or system files were deleted or infected with viruses.
Your only option is to do a operating system repair or a complete new install of Windows.
I recommend you do a new install.
Posted on Nov 23, 2008
  • 50 Answers
SOURCE: i need solution
Ok, this is a misworded error message on dells end. this laptop does not have a modular bay instead it has a locked in disc drive. Based on what i have seen on other dell laptops i would have to say the cd drive is going bad. To test this try removing the cd drive. Power the laptop on and push the eject button then power the laptop off. Flip the laptop overand there will be a screw to hold the drive in, this screw will be close to the center and will be the only screw in a square hole, remove this screw. Now if you followed my directions, you should have the drive out. Pull the tray out as far as it will go then grab the two sides closest to the laptop and gently pull it out. If you are having problems you can stick a flat screw driver in the square hole and push the piece of metel to the side to remove.
Now power the laptop on it may say something about there not being a cd drive(optical drive) if it does not say: "the device in the system modular bay cannot be identified" then you need to replace to CD drive.
Posted on Dec 07, 2008
SOURCE: this screen comes up when it is turned on: "The device in the system modular bay cannot be identified, etc.
I had the same problem.  I took out the optical drive, and powered it on, and it worked.  I may have to purchase a new optical drive?
Posted on Jan 24, 2009
  • 2692 Answers
SOURCE: bios password dell d800
Remove BIOS battery. Short BIOS jumper or leave the battery out for a long time(Over night,maybe) This should default the BIOS to having no pass word present.  If that doesn't work then evidently Dell has one within the BIOS . Just ask them.
Posted on Feb 17, 2009
Hi my dell d610 does not recognise any dvd rom i
insert a good quality dvd in the drive. If no response, go to my computer and select dvd drive and double click, it may open. GL
Aug 19, 2013 | Dell Latitude D610 Notebook
My Dell D600 gets a system modular bay cannot be identified error. What do I do/
Specify tag number, and windows version used. But, usually is the chipset drivers. Another common issue is the external card reader not being installed by default inside windows.
Aug 10, 2010 | Dell Latitude D600 Notebook
Can hardly see anything on the display of DELL latitude D800
try to adjust the backlight of the LCD by pressing and holding the FN key and press the up arrow key. also try to update the video/graphics driver of your Dell Latitude D800 . you can download it here: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PNT_D800&os=WW1&osl=en&catid=&impid=
Jun 10, 2010 | Dell Latitude D800 Notebook
FIND THE AGE OF LAPTOP
The D600 line was introduced in 2004. The only accurate way to find the exact age of your laptop, or the PRODUCTION DATE is to contact Dell. Otherwise you would only be able to find out the general date which was the 2004-2005 years. After that they moved on to the D6X0 lines...D630, etc as the processors improved. Some more info on your unit
Latitude D600
The D600 (and simultaneously-introduced D800) was Dell's first business-oriented notebook based on the Pentium-M processor; it used the first-generation "Banias" Pentium M chips running on a 400 MT/s FSB on DDR memory. It had a PATA hard drive and a D-series modular bay, and used an ATI GPU Radeon 9000. It had a 14" screen, in regular (non-widescreen) form factor. Unlike later D6x0 series machines, both memory sockets were accessible from a single cover on the bottom of the system.
Many Latitude models had a near-clone Inspiron, in the case of the D600, it was the Inspiron 600M. Differences include that the 600M does not work with the Dell D-Dock, and the case styling is slightly different. The motherboards, screens and hard drive caddies are all physically interchangeable
Jun 02, 2010 | Dell Latitude D600 Notebook
Dell latitude d800 laptop i have forgetton the
You can reset the windows password by using 3rd party tool.
you can visit this site (there are options for the tools and intructions how to do it)
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
Mar 28, 2010 | Dell Latitude D800 Notebook
When I turn on the laptop ...it says the dvice in the system modular bay can not be identified
Did you ever solve the non-recognition problem?
My C840 fails to recognize the/an extra HD in the modular bay, after I "overfilled(??)" it.
What to do to regain access to information stored on HD that the computer no longer recognizes? (Other components, including other HD's continue to work ok in the modular bay).
kcdd30a@aol.com
Nov 07, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Sound driver
Select your model on website below to download drivers:
Dell Drivers and Downloads
Mar 04, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Dell Latitude D800
This may be SpeedStep slowing the processor to save battery life. It speeds up when it is needed.
Dec 13, 2007 | Dell Latitude D800 Notebook
Dell Latitude C640 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
