Question about Home
Twyford duel flush cistern
My flush button is stuck in the down position, how do i get it back up ?
    Sergeant:
    Champion:
  • 242 Answers
There is a spring under button or a weight replace it or re balance it
Posted on May 11, 2014
  • 5 Answers
SOURCE: Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
Posted on May 18, 2009
  • 129 Answers
SOURCE: i needs new valves for my dual flush, close
No I'm sorry they do not. You might try plumbing supply house in your area.
Posted on Sep 26, 2009
  • 69 Answers
SOURCE: A part of a Top Elite double flush cistern has snapped
Yes
Posted on Oct 07, 2009
  • 51 Answers
SOURCE: flush mechanism is stuck; unable to push buttons
If it's electrical powered, you may have to spray alcohol in the buttons to free them, if urin or other contaminants have gotten behind them to make them stick to were there stuck.
Posted on Dec 27, 2010
packrat1948
  • 528 Answers
SOURCE: the large oval button on top of cistern which is
Yes go to the toto dealer site ( http://www.totousa.com/Default.aspx?tabid=185 ) and there you can order the parts.
Posted on Jan 30, 2011
Caroma duel flush cistern 20 yrs plus not flushing when buttons pushed
well past used by date
parts will be difficult to get so consider a new cistern
Jul 05, 2017 | Caroma Home
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Tavistock Vortex White Slimline Concealed Cistern | VOR790
the clear and the blue pipes control half and full flush. They should both be connected to the main cistern. The small button should give a half flush.
Mar 26, 2012 | Home
Buttons on our concealed dual flush cistern have stuck in, water constantly running into pan?
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Jul 08, 2011 | Plumbing
Just installed a newbury toilet and we can't get the cistern to fill without taking the lid off everytime and manually pushing down the lever. Then we have to lift it again when the cistern is full....
One of the flush buttons is pushing on the valve keeping the seal up. Not sure how the Newbury flush button opperates the valve but you need to shorten the push rod if it uses a rod or lengthen the chain if it uses a chain. Why are you asking this in the stroller section?
Jul 04, 2011 | Baby Gear
Cant get the lid off a push button cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Feb 01, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
I have a toilet with a push button flush mechanism (allowing half or full flush). The toilet has a macerator behind it. If you flush the toilet and the macerator jams, the push button stays stuck in and...
This seems like a problem with your cistern and not your macerator - I have a similar set up and if your push button is stuck you need to check the mechanism in the cistern - also you should have an overflow that drains into your loo within the cistern so you should check this for blockages as well.
Oct 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Home Logo
173 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
