Question about Miele Novotronic Premier 500 Front Load Washer
Water leaking from dispenser drawer - Miele Novotronic Premier 500 Front Load Washer
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
Kenmore front load washing machine leaking water from under the the detergent dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again. If the dispenser still leaks, then I recommend calling a service technician to diagnose and fix this problem.
May 01, 2012 | Kenmore Washing Machines
Water leaking from the dispenser on front load washing machine
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 12, 2010 | Kenmore HE2 Plus Front Load Washer
My Whirlpool Duet washer is leaking from the
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is leaking water from the detergent compartment
Jun 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool duet washer leaking/pouring water out of soap dispenser
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My detergent drawer will randomly leak out water at the beginning of the wash cycle only. What's up?
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Dec 09, 2009 | Kenmore Elite 45986 Front Load Washer
LG WM-1285FHD Leaking from Dispenser Drawer area
There is a problem with the dispenser assembly where the drawer enters.  You will have to have it checked by a qualified LG technician to see what the problem is.
Apr 27, 2008 | LG WD-1280FHD Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
15 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
