Question about CDA Washing Machines
CDA C1920 dryer not heating up when running, timer ok, tried the red reset button on the back of the machine, still not working?
4 Suggested Answers
SOURCE: Dryer not working
hi i ve got a candy aquarius washer dryer and the spin cycle has stopped but the wash is still working can you help thanks
Posted on Aug 26, 2008
wiringlunati
  • 576 Answers
SOURCE: does not heat ; timer OK, natural gas dryer gas
In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on your specific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINE UNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week. Good luck.
Posted on Jan 03, 2010
  • 96 Answers
SOURCE: No heat WD62 on drier or water heater
Check the thermistor is plugged in,,,it's next too heater
Posted on Jun 14, 2013
Testimonial: "Thanks Have checked all wiring no breaks or disconnected wiring ."
Whirlpool dryer won't heat
Check the back of the machine to see if there is a tiny red button. This is a thermal safety cut out button, which you may need to just press to reset
Dec 26, 2013 | Whirlpool Dryers
I have a Kenmore 70 series dryer. The dryer runs but will not heat. I have had all fuses, heating element, and thermostats tested but it still will not heat. Any thoughts?
Notes: Check all components on dryer with at least one wire removed and all have continuity or 0 ohms.
Have checked circuit breaker and know for sure 240 volts is going in machine (motor runs on 120v heater needs 240v).
Ok the next thing to do is find the heavy red wire going into the timer. Remove the red wire from the timer. Set the timer on heat dry cycle (power if off) Chck from that leg of the timer to any other leg on the timer for continuity. or 0 ohms. if you get nada then the contacts inside the timer is bad. My video:
Sep 10, 2013 | Whirlpool GEQ9800L Electric Dryer
Dyer will not dry
The CMT switch is the centrifugal motor switch mounted on the dryer motor. It has spring loaded weights that retract it back into the open circuit position between Number 1 and number 2 on either end of the quick connect. These 2 are thick red wires and go to the heater. If the motor is not running the heat will not come on To check the cent switch manuall move it by sliding the black disc on the shaft Then check between the 2 ends to see if you have continuity. The chances of the cent switch being faulty are slim and none. The motor circuit is on 120 volts because the motor is a 120 volt one. Only the heater needs 240 volts. So if one side of the breaker is bad or tripped you might not get any heat. make sure you got 240 between L-1 and L-2. Next thing to check (with machine unplugged) is the fat red wire on the timer. Remove it and check from that leg and any other leg on the timer. If you cannot get a reading between that terminal and any other terminal on the timer and you moved it around the dial to do the check then you have a bad timer.
Sep 11, 2012 | Kenmore Dryers
Maytag Dryer model DE212 no heat everything else works? Checked sensors and switch block on drive motor all seem to be ok how to test timer switch?
the heater element may of burnt through, or they may be a red reset switch on the rear of the dryer.
Nov 17, 2011 | Dryers
Dryer's drum won't rotate, but heat & timer works.
Hello there:
This is normally caused by a belt that has either broke or the motor for the belt has failed and locked up
S o what i would do is to first see if you can manually turn the drum by hand and if so than if you turn on the dryer and hear the motor that turns the drum running or humming you can assume that the motor is ok and that he belt has failed in this case get a new belt and the appliance parts store should be able to give you the proper diagram on how the belt needs to back on but if not let me know and i will be able to get it for you ok? now if you do not hear the motor hum than try to unplug the machine and leave sit for 30 min and than plug it back in and than see if it now tries to run but if no motor sound than youwill know that the motor has either failed and needs to be replaced or that there is a problem with the thermal fuse that is on the controle panel behind the start button ok
i can help if there is any more issues that you need help with.
Hope this is very helpful for you.
Best regards michael
Dec 19, 2009 | Kenmore Dryers
Dryer does not heat model td-v75120E
Hi, open the back panel. You will find a black cutout switch with a red button on it. Press the red button to reset the heating mechanism. Close the back panel and test the machine.
Sep 10, 2009 | LG DLE2532W Electric Dryer
I have just moved into a house with a C1920 tumble with no heat
If there is a reset on the back you may have to push pretty hard to reset it. If it doesn't click it may be faulty.
eric
Jun 29, 2009 | Dryers
CDB115
should be a reset switch on the back of the machine usually just a red button or small hole if not there is over heating protection on the heating element or elements if it has 2 heat settings ,but these cannot be reset have to be renewed
Oct 05, 2008 | Candy CNW156 Front Load Washer / Dryer
Bosch Exxcel tumble dryer error code F:09
Mine did this. Because the bottom left filter was blocked the overheat cut out had tripped. This is inside the rear of the machine accessible after removing the rear panel
Aug 10, 2008 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing Machines Logo
56 people viewed this question
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
