Question about Kyocera FS-1118MFP Laser Printer
Kyocera fs-1118mfp may copier display error code C6020 please help forthe solution
  • 24 Answers
Remove the fuser unit and check if the heater lamp, the thermostat and/or the thermistor are broken
Posted on Sep 28, 2014
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
  • 66 Answers
SOURCE: Copier fixing problem
Hi
The A-3200 error indicates a scanner lamp problem.
It can either be a loose connector or more likely a lamp or inverter PCB.
Another cause can be incorrect shading position, by moving the contact glass this may fix it.
Posted on Jul 15, 2009
anantakumarj
  • 330 Answers
SOURCE: i'm having an error on
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
Posted on Sep 24, 2009
  • 241 Answers
SOURCE: How to solve error c6020 for Kyocera KM-2035
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
Posted on Jun 09, 2010
How do I unlock my printer a Kyocera fs 1118mfp when error C6000 appears?
Press the system menu/counter key,Select Service setting using the up/down cursor keys.While pressing the start key and the # key, press the enter key.then select 163 Resetting the fusing problem data Description Resets the detection of a service call code indicating a problem in the fusing section. When a service call concerning the fusing section occurs, turn the power switch off and open the front cover. Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode. Purpose To prevent accidents due to an abnormally high fusing temperature. Method 1. Press the enter key. A selection item appears. 2. Select Execute using the up/down cursor keys. 3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.) Completion Press the back key. The indication for selecting a maintenance item No. appears.
Mar 27, 2015 | Kyocera FS-1118MFP Laser Printer
C6020
my copier kyocera fs-1118 mfp display error code C6020 please help me the solution.
Mar 10, 2012 | Kyocera Copystar CS-1820 Black and White...
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
Showing 'error occured call service person c6400'
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
I'm having an error on my kyocera ecosys FS 1118MFP. The message is "Error Occurred. Power switch turn off and on again Cf2ff". Please can you help?
this is
PWB
Jan 14, 2009 | Kyocera FS-1118MFP Laser Printer
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera FS-1118MFP Laser Printer Logo
190 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
