Question about Capcom Devil May Cry 4
Dat.bat file is missing - Capcom Devil May Cry 4
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 14 Answers
You can search the file on google and you can download it
Posted on Jun 12, 2015
    New Friend:
    Problem Solver:
  • 11 Answers
Looks some file may be missing...try re-installing the game.. Or else install in some other drive rather then C:/ If you still have a problem , try going to , and try getting some help
Posted on Jun 03, 2014
How to change a Dat file so I can open it on my Samsung tablet
DAT is a file extension that's mostly found on video CD. It is usually used to store MPEG-1 encoded video on VCD. This kind of video file is file format that are not playable in the default Android video player.
But don't worry, there are ways to make it playable. In this article, I'll show you how to play DATvideo file on your Android device.
To be able to play DAT video file in your Android device, you should need the help of a third-partyvideo player app. In this case, I suggest you to use MX player.
MX player is one of the most popular video players that can play almost every video format. It also play all resolutions that supported by your device.
If you don't have one, you can download it for free at Google play store.
Once installed, open the DAT video file with your file manager app and the video should be loaded and played by the MX player. However, you're unable to load DAT video file on 'My files' or 'Gallery' app, as well as 'MX player'. To be able to open DAT video file directly from your Gallery app or MX player, you should rename the file extension from .DAT to .MPG. For example, filename.dat change to filename.mpg. Once you're done, the video will appear on your MX player list and you can now play the video file on your Android device.
Oct 23, 2014 | Samsung Cell Phones
Windows vista - ZTE AC2726 wireless data modem HSD USB Card unins000.dat file
same here . use this file and put to the missing folder. then try to install or uninstall
Apr 22, 2012 | Computers & Internet
How to look for registry file dats missing in d system'?
I would go to Start and type in registry, click on registry and go to properties and do an update on the driver. You can also, just do a search at Start for the missing file.
Registry, if you not aware of, cleans files not used on a regular basis, so to give you more storage. You should be able to retreive your missing files.
Here is a link to Manuals you can get on line FREE!
Kind regards!
Sep 13, 2011 | Computers & Internet
Cannot find directory in commamd prompt
you want to open commamd prompt? press start+R and type cmd
Oct 26, 2010 | Computers & Internet
When i start my hp scanner then 1 warning show. the warning is " where is the file of hpf2vw10.dat " so what can i do ? pl. help me.
Uninstall the scanner drivers and install them again from the cd given or downloaded from online.
The dat file is missing due to corruption or a bad install.
Dont worry. This should solve the problem. Cheers!
Aug 16, 2010 | Computers & Internet
Error code :0xc004e002
The error message appears if the file in which the activation status of Vista  is faked, is corrupted or missing.
Once you are at the error message screen you will have an option to contact support once you click on it that should open Internet explorer and once you have the Internet explorer type in the address bar the following commands:
 -  net stop slsvc   (it may ask you if you are sure, select yes) -  cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
 -  rename tokens.dat tokens.bat
-   cd %windir%\system32
 -  net start slsvc
 -  cscript slmgr.vbs -rilc
and wait for the process to finish. Reboot again and activate Vista.
May 09, 2010 | Computers & Internet
It doesnt want to start it says what im describeing.
This behavior can occur if the Windows\System folder is missing or renamed, or if the PATH line in the Autoexec.bat file is missing or does not include the Windows\System folder.
To resolve this behavior, use the appropriate method:
Method 1 loadTOCNode(2, 'resolution');
  1. At the command prompt, type: dir vmm32.vxd /s If the Vmm32.vxd file is not found, you must install Windows 95 or Windows 98 again. If the Vmm32.vxd file is found, note the folder in which it is located, and then continue with step 2.
  2. At the command prompt, type the following commands, pressing ENTER after each command cd windows
    ren folder system
    where folder is the folder you noted in step 1.
  3. Restart your computer.
Method 2 loadTOCNode(2, 'resolution'); Using a text editor (such as Notepad), edit the Autoexec.bat file and add or modify the PATH line so that it includes the Windows\System folder. For example, add the following line to your Autoexec.bat file: path=c:\windows\system
Hope this helps,
Mar 16, 2010 | Toshiba Satellite 2060CDS Notebook
Can's install SW on Treo 755p error "unable to locate users.dat"
users.dat is created in your named profile directory on the drive in the Palm folder. If it is missing, your computer can't sync properly to the device. Do a backup of your device using the palm desktop, this should recreate the file in your profile folder on the machine.
Oct 02, 2009 | Palm Treo 755p Smartphone
Error message says: missing file, aquatica.dat
This is a system files. These are basic file's in a window directory.Regarding aquatica.dat, it is a multimedia file component.
You can repair this by downloading .dat file from .dat database. You can easily search the file online and add it. If you purchase a software, it would cost you certain bucks. Better reinstall windows or restore.
Computer can be affected by the missing of these files. It depends on How many files are missing, configuration of the PC, Virus, Malisware, Adware etc.
The simple option - Restore or Reinstall, if not a tech.
Let me know,if need any further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 25, 2009 | Dell Computers & Internet
Win 98 se file trouble
get hold of a win 98 boot disc (search the net) as it will have the files you are looking for, i am sure. copy them to your hard disc c:\windows or c:\windows\system
put them in both as i cant remember what one they go in. (it will not hurt in both).
good luck
Mar 26, 2008 | Computers & Internet
Capcom Devil May Cry 4 Logo
208 people viewed this question
Top Capcom Video Game Consoles & Games Experts
Piyal Perera
Piyal Perera
Person On the...
Level 1 Expert
Tre Elkins
Are you a Capcom Video Game Console and Game Expert? Answer questions, earn points and help others
