Question about Vestax BDT-2500 Turntable
Repairing tone arm of a pioneer PL 200!
My pioneer pl 200 tone arm counterweight post is broken off! is it fixable or i should buy the part?
    Sergeant:
  • 432 Answers
I have the same problem with two vestax parts, which of one is round so sprayglue and three turns around it with thin koper cable.and after that sandpapered itagain and another layer glue, but i had no choice... the part ain't available en a couple of days ago my backside of a pdx 2000 spantanious broke of, but carbon wil hopefully fix it. You need to know of which plastic it's made and get the right glue, but you nee some glassfibre orso also on the inside , or it will brake
Posted on Sep 19, 2014
How do I access tone arm belt and motor on a Pioneer PL-L30 turntable?
Try lifting up the turntable mat. You should see a hole. Note how it fits before removing the belt.
Oct 10, 2014 | Audio Players & Recorders
Pioneer pl-41 replacement tone arm assembly?
this isvthe site for you, http://www.vinylengine.com/turntable_forum/viewtopic.php?t=17098
Sep 04, 2014 | Audio Players & Recorders
Can't find replacement cartage for Pioneer PL-200
Try a computer search. There are sources out there
Jul 29, 2012 | Pioneer Audio Players & Recorders
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
I have a Pioneer PL-740 turntable that works extremely well, except there is zero damping when either lifting or dropping (and I mean dropping) the needle. I know there is generally a hydraulic oil that...
most turntables actually only dampen during automatic play and return (eject) not when manually manipulating the needle. Better turntables will have a counterweight at the back of the arm behind the pivot point, but that is to decrease wear on the vinyl and increase needle life and audio fidelity in the higher end.
Some turntables have a lifter arm that is dampened, but if your player doesn't have such a mechanism, or if it has one and you choose to manually manipulate the needle without it's usage, there is no dampening.
The fix unfortunately is to buy a turntable with a dampened lifter arm, and to use the arm when lifting and lowering the needle.
Mar 23, 2011 | Pioneer Audio Players & Recorders
Pioneer turntable is powering up but not not spinning?
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 18, 2011 | Pioneer PL-990 Turntable
My Pioneer PL-112D turntable has a broken drivebelt, is it possible to buy a new one, and is there a diagram showing the belt "routing". Thanks.
I don't believe this belt is being provided by the Pioneer. So I did find another option at a reasonable price on E-bay.
http://cgi.ebay.com.sg/TURNTABLE-DRIVE-BELT-FITS-PIONEER-PL-12D-PL-112D-/290432607483
Jan 17, 2011 | Pioneer Audio Players & Recorders
My Pioneer PL-570 tone arm returns but will not shut off. It keeps playing like the repeat button is on. I asked this question before and you replyed that on page 8 of the service manuel it shows the...
I have a possible solution to your problem, but will need to talk you thru it. You can register at AudioKarma.com and send a private message to Ghazzer.
Jun 25, 2009 | Pioneer PL-990 Turntable
Pioneer PL-570 turntable (c.1973)
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
Sep 16, 2008 | Pioneer PL-990 Turntable
Vestax BDT-2500 Turntable Logo
124 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
