Question about Samsung RSH7ZNRS Stainless Steel 513L American Style Fridge Freezer Side-by-Side Freezer, A Energy Rating
Keeps going on and off fast freeze - Samsung RSH7ZNRS Stainless Steel 513L American Style Fridge Freezer Side-by-Side Freezer, A Energy Rating
Heater not getting hot
Could possibly be the thermostat. also could be the heater core. keep track of it though, cause if it is anything like mine, it will start to go down hill fast. Mine started that way, and then started using anti-freeze without it leaking. Makes for a fast blown head gasket and or blown motor
Mar 02, 2014 | 2001 Pontiac Aztek
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Dell latitude e6400 freeze
might your memory is low or need replacement.
Jul 19, 2012 | Dell Latitude E6400 Notebook
Do you keep the fastfreeze on the freezer going all the time
no the fast freeze bypasses the cold control and will cause the compressor to run too long it is there to bring the temp down for freezing only if left on you will also get a lot more freezer burn
Mar 15, 2011 | Kitchen Ranges
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
My AC keeps freezing. Condenser pipes freezes all the time and the repair men just keeps adding freon. What is the problem?
Hello MCOMSTI You have a freon leak that MUST be found & repiared so the system will keep the charge.A fast leak is eaiser to find,look for a oil/grease stain anywhere on the system,when you loose 1/2 system charge you make ice.
Aug 05, 2010 | Goodman CLQ30AR32 Air Conditioner
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Mar 23, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Magic Chef MCCF5W do not works. Fast freeze is working.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
My sony mp3 player keeps freezing and i have to wait untill the battery dies to get it going again
Maybe the problem is that you are moving to fast for the mp3 plyer and it slows down and freeze up u have to wait for it to respond
Jun 19, 2008 | Audio Players & Recorders
Samsung RSH7ZNRS Stainless Steel 513L American Style Fridge Freezer Side-by-Side Freezer, A Energy Rating Logo
12 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
