Question about Nokia Lumia 710
Will notcharge phoned died now will not charge
Batery notcharging
There can be many things that cause this. Is your port where you plug it in bent or chipped in any way? Is there something stuck in the charging port, could the wall charger be fried, could your charger cord have a short in it, could there be dust up in the charging port, is your battery wet, could your phone be outdated and you need a new phone.
Feb 16, 2015 | Cell Phones
Charging jumper samsung s3770k
Write your answer... samsung gt - s3770k charging problen
phone is on and notcharging
phone is of is ckarging
connect this charger and dack this adoptor light on
Jan 17, 2014 | Samsung Cell Phones
Nokia6700c notcharging
Hello::';;'
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 21, 2013 | Nokia Cell Phones
How do i know if my nokia E63 is charging
my e63 nokia is have charging problem. If i plug it light it will show charging and immediately notcharging. what can i do pls?
Aug 01, 2012 | Nokia E63 Cell Phone
Notcharging
Try use a similar charger to charge it, if it does not still charge it, it means the charger is not the problem, the problem is the charging port.
The problem with your phone is the charging port, all you need to do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port as advice and you see that your phone will charge.
Take care.
May 26, 2010 | Motorola Mobility W220 Cellular Phone
NOTCHARGING
Try a different charger to see if your charger is OK. If it is fine then the connector socket on the phone could be faulty. Solder it. Or it could very well be that the charging circuit is faulty. Then help from Nokia Care is warranted.
Aug 27, 2009 | Nokia 1208 Cellular Phone
NOT CHARGING
That means that life of ur mobile's battery is over and u need to buy a new mobile battery.
Jun 12, 2009 | Nokia N95 Cellular Phone
Nokia 6070
Have you tried a new charger?
New battery?
Check the charging port where the charger plugs into the handset, there should be a small pin inside, if you cant see this then its probably broken off and you will need to replace the charging connector
May 09, 2009 | Nokia 6070 Cellular Phone
Charging problem
Is there a fix for this problem, or should i just ram the phone and usb charger back down Orange's neck...
Oct 25, 2007 | Cell Phones
Nokia Lumia 710 Logo
18 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
