Question about Vehicle Parts & Accessories
93 chevrolet remote door lock1500 - Vehicle Parts & Accessories
2009 saab 93 door will not open with remote have no key
Real door key is inside key fob.. Push the Saab symbol to separate them.
Apr 20, 2014 | 2007 Saab 9-3 Aero Convertible
Lexus door lock
I can help you with the drivers door. Simply put a screwdriver in the hole between outer door edge and lock mechanism. Push mechanism towards inside of door. The reverse of what happened when you accidentally locked the mechanism. I have done the same thing
Jun 10, 2017 | 1993 Lexus Es 300
Lexus 93 ls400 remote not working for driver's door
if all other doors work the door lock actuator needs replaced most likely. if door switch works the same. if not then it could be a bigger problem in the circuit or remote control module. use a meter to test for signal to lock actuator. if no signal then ck control unit. if signal replace lock actuator.
Aug 19, 2012 | 1993 Lexus Ls 400
93 Cadillac DeVille key fob programming issues.
I too own a '93 Sedan Deville. I had the same problem you are describing. There are so many brands of remote controlled systems that your problem defies a simple solution by someone like myself not in the business..I went to a store where they specialize in audio equipment and alarm systems. A good tech will be able to program your system in a New York Minute. There might be a small charge. Audiovox manufacturers systems under many different names. Their customer service people are pretty sharp and if your unit is of their manufacture they will be happy to walk you through the programming system on the phone. I have done this myself and they will stay with you 'till it works. IF it's an Audivox system their customer service phone number will be molded in to the key fob. Hope you find this helpful.
Sep 25, 2017 | 1993 Cadillac DeVille
Didn't know my 93 vw golf had an alarm, now I had to disconnect the battery to shut if off.. what do I do to fix this?
I'm not sure if you have an aftermarket or factory alarm, but try this: hook up the battery and try unlocking/locking the door with the key. If you have a remote door lock, hit unlock/lock on that. I have come across a couple of cars this was all it took to stop the alarm, never tried with a VW though. Hope it works, good luck!
Feb 28, 2010 | 1993 Volkswagen Golf
Door handle pulls but door doesn't open, 93 chevy lumina coupe 3.1 engine
Sounds like clip holding linkage(rod) may have come off, and linkage did the same because of it. You may have to remove interior door panel to investigate & re-attach.
Oct 28, 2009 | 1993 Chevrolet Lumina
Chevrolet 2500 crewcab - rear door auto lock shut off
try punching the remote lock button twice. experience with 4 door s-blazers shows that it has to be done twice to lock all 4 doors. also look for "child safety" switched for the rear doors that may be disabling remote locking for the rears.
Feb 18, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Vehicle Parts & Accessories Logo
13 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
