Question about Jandy Lite2 LG400 Ceramic Compact Heater
Jandy Lite 2 - Pilot goes out when I turn to On
I have a Jandy Lite 2. When I turn the knob to pilot, depress and hit the ignition the pilot immediately lights. I continue to hold down for over a minute and then let it up so that I can turn to the on position. As soon as I let the pilot switch come up the pilot goes out.
Any advice?
  • 29 Answers
Sounds like you need a new thermo couple. found at most hardware stores
Posted on Jun 23, 2009
Pilot light lights but goes out when I turn the main heater on / off switch
clean silver supply line to pilot generator sounds like cob webs not enough gas going to pilot make sure pilot generator is good also
Aug 24, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Jandy LG250N pilot won't stay on after releasing switch on gas valve. Main switch on unit is off. I am able to keep pilot flame on for one minute by depressing switch but pilot always goes out after...
Thank you for posting your question here on Fixya.com.
No, the pilot generator or the pilot head itself is the issue. You need a good, solid blue flame across the generator to get enough power to hold the switch open when you let go of the knob. If the pilot flame is week or not aimed across the generator it will not stay lit.
If it is but the generator is old and weak, it will go out as well. If you can see the pilot flame and it is a nice blue color, replace the generator. If it is not, disassemble the pilot and either clean it out or replace it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Aug 06, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lite won't light
I believe your heater uses a" Glow plug" style igniter not a traditional pilot.This type takes a few minutes to lite. Be sure the correct pump is running,the gas valve is turned on, and the Bypass valve is at least 1/2 way closed.Also make sure you have at least 10 psi on the filter gauge.
Oct 08, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot will lite but burners will not kick on - Jandy lite 2 400,000BTU pool heater Me too.. was able to fire it up by tinkering with the switch that goes from "Pilot" to "On", but doesn't always work. A...
No, do not mess with wiring. If the gas does not ignite and the pilot goes out, The thermocoupler is faulty. This is the probe that should be sitting at the tip of the pilot flame. When it gets hot enough it allows the main gas valve to open when you put it to ON position. If the pilot light goes out, It shuts off the gas for safety. Summary, Bad thermocoupler. Easy, inexpesive repair. Let me know please, if you need further help.
May 28, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Jandy Lite2 LG400 Ceramic Compact Heater Logo
229 people viewed this question
Top Jandy Heating & Cooling Experts
Craig Butler
Craig Butler
Willie Burks
Willie Burks
Level 1 Expert
David Spradling
David Spradling
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
