Question about Zenith XBV442 DVD Player/VCR
Zenith dvd player zda510 will not play any disc, says 'load', then 'err'.(no remote).tried the 15 second hold stop button routine - no difference
...there are no more details, that's it, that's all.
SOURCE: Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Posted on Dec 27, 2006
  • 97 Answers
SOURCE: DVD Player will not play 20th Century FOX disks
The Panasonic is not "region restricted". This is a security safeguard by studios to keep people from region 1 from using region 3 content. Some material is released in other countries first and later in others. This keeps other regions from using the content from other parts of the world before it is relaesed by the studio there. Your Zenith is not a region free player and the Panasonic is. There is sometimes hacks on Videohelp.com for DVD players to be set to "region free" but not all DVD players are built with it. SONY is another non-hackable DVD player.
Posted on Jun 11, 2007
SOURCE: zenith xbr616
I have the exact same issue, DVD don't play. The VCR works & the cds will play on DVD side, but it will not play DVD. Warranty is expired and we barely used it.
Posted on May 23, 2008
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
SOURCE: Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Posted on Feb 17, 2009
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
Zenith XVB422 DVD VCR comb
Hi skielty58...I just saw your post, so I haven't done any research yet. However, IF should you see this post prior to my, or any other contributors forthcoming updates which should contain a certain resolution, I would like you to try something during the interim. Play a dvd, and although showing the blue screen, allow to play for about a minute. Now, using your remote, press and release STOP, and within 1 second, Press And Hold Stop for 10 to 15 seconds. This trick is reliant upon the timing sequence, so, you may want to try it more than once. Another trick that I'd like to suggest is that again, after allowing a dvd to play for a minute, simultaneously press select and stop on the player...Please update your post whether positive or negative so other potential contributors have the benefit of ongoing history...good luck my friend
Jul 31, 2007 | Zenith XBR413 DVD Recorder
I have a sylvania dvd vcr combo and the progressive scan light is on and it wont play dvds. How can I fix this?
Try the (Goldstar and Zenith) trick - with the unit on, but no discs inserted, press and hold STOP button on the front (not the remote) for 10 seconds, then release. This should revert progressive back to normal interlace output for your TV and may also turn off the progressive LED indicator on your unit.
I mentioned 2 other brands in parentheses - because the (press and hold STOP for 10 seconds) trick works for progressive on those.
Apr 10, 2011 | Sylvania (SRDD495) DVD Player/VCR
HOW DO YOU TURN OFF PROGRESSIVE SCAN
Try this: with the unit on, but no disc inserted, press and hold STOP button on the front panel, not the remote - for 10 seconds, then release. This should turn the progressive scan off and restore your picture on TV (interlace should be the default setting in the DVD player). This trick works for Zenith DVD players as well.
Apr 10, 2011 | Goldstar GBV241 DVD Player/VCR
Stuck with progressive scan mode
My dear friend try with this,turn on the dvd take out the disc open the tray now push for 5 seconds the button stop.Good luck.
Jun 18, 2008 | Zenith XBV243 DVD Player/VCR
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Progressive Scan
SOLUTION #1
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
Zenith XBV442 DVD Player/VCR Logo
50 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
