i have fixed the thermostat, replaced the head gasket, and had the radiator redone. the temp gets to about 240-260 and pushs the water out the coolant resevoir. does this after about ten minutes or so. the coolant resevoir cap is busted
Did you check the head for when you had it off, This needs to be magna fluxed at a machine shop to check for heat .If the head gasket was replaced properly and torqued in the right increments and you replaced the thermostat and had the radiator redone this is about all it can be ,You can do a compression test to verify.
Was this solution helpful? Show your Appreciation by rating it:
