Question about Shimano Pro Scio Cycle Computer 2013 Black
Why does pro scio alti **** so much
If the sensor moves even a centemiter, it stops working
Do toyota altis 2003 has a starter with carbon solenoid? My altis initially is hard start then finally won't start anymore.
No not carbon in the solinoid. Has the battery been load tested on a special machine teser? Do that first.
Sep 14, 2012 | Cars & Trucks
Corolla altis 1.8E ...bought in 2009 abs light on once start the engine for a second.... front driver tyre sound loud from normal if driving below 100 km/h..
If the ABS light goes out, and stays off you do not have an ABS issue-it is doing a self-check for that second. As for the noisy tire, you could try moving it to a different location to see if the sound moves-if so, you need a tire, if not, check your wheel bearings at that wheel.
May 23, 2011 | 2008 Toyota Corolla
I can not set altitude on my TCM Winter sport Watch
Go to altitude view (ALTI) - may need to press 'Sensor' (top left) once, and then 'Mode' (bottom left) to display.
Press and hold Mode until display starts flashing. Keep pressing Mode until the setting you want to change is flashing, then use right-hand side buttons to change.
Press and hold Mode again to get out of the setting interface.
The different altitude settings which you can change between using the Start/stop (top right) button:
ZERO - for use when skiing or when you want to measure a relative change in altitude.
ALTI - Input known measurement above sea level
SEAP. - Current air pressure
F.DEF - Factory reset barometer to 1013.2hPa
Apr 06, 2011 | Sport & Outdoor - Others
Altitude auto rec function
I cannot delete my memory of alti function
Jun 20, 2010 | Casio PRG-40T-7 Pathfinder
Toyota corolla altis 2003, driver side power window is not working properly when using the auto button, if you close the window using the auto button it automatically closing but when it reaches to the end...
I had the same problem with my 2002 Altis. I found a solution after a lot of research and reading in the web.
1. Remove the power window motor from the regulator (mechanism).
2. Reconnect the power motor to the electronic controller(switches).
3. Perform "Auto Down" an wait until the motor stops.
4. Put a mark in the motor gear.
5. Perform "Manual Up" slowly until the gears rotates around 6 times but not greater than 10 times.
6. Remove the motor from the electronic controller.
7. Re-assemble whole power window assembly.
Apr 02, 2010 | 2002 Toyota Corolla
Toyota Altis 1.8 E Using oil, and blowing smoke
Either your cylinder rings are failing or your headgasket has broken and is the culprit. One final possibility is that your EGR value is plugged.
Feb 21, 2010 | 2004 Toyota Corolla
To locate the speed , and crank shaft censure on 2003 nissan alti
The crank sensor is on the back side of the engine next to the firewall. Not sure if this car has speed sensor.
Jun 17, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
My old field watch is showing an err (error) and the internal klight wont work
I changed the battery in my PRT 50 but Alt and Baro still not working the light and Compass however is??
Oct 27, 2007 | Watches
Shimano Pro Scio Cycle Computer 2013 Black Logo
101 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
