Question about Dometic Rooftop RV Air Conditioner
Carrier A/C in RV won't run
Fan will run in fan only mode...but when you turn it to cool it will kick off. the green light is blinking 5 times. and there is a red light flashing... it was cooling great and then it seemed not to be cooling very well. turned unit off and let set a few hrs. turned back on and was not cooling turned off and cleaned filters(they were not really dirty) replaced them and turned unit back on and it ran about 5 to 10 minutes and shut off and will not come back on.
    Problem Solver:
  • 15 Answers
Check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Posted on Jan 29, 2010
MY RV Carrier AC has a blink 5 pause then blinks 5 again. Unpluged circuirt board and the fan and compressor will come on for a minute or so and the nothing no fan no compressor. The fan mode works
Well I'm not sure what model unit you have but I found a manual online for the AirV series that has a 5 flash code. States that to be a compressor drive issue. If yours is an AirV series, call a technician. No help in the manual.
Oct 07, 2017 | Heating & Cooling
We are in a 5th wheel RV. We have a factory installed Carrier a/c in the kitchen. Lately, it shuts off during the night and we have to reset it in the am in order for it to work. It works fine during...
If the outdoor temps are cooler than inside, AC's are not made for this and will not work well if that is the situation, it floods liquid to the compressor which will overload. will it reset within 20 mins of going off? if so the board/stat are suspect, if not the compressors the villain and its tired and cant handle the other than design condition of 95 F outdoor/80F indoor.
Sep 09, 2011 | Dometic Rooftop RV Air Conditioner
I have a Carrier RV Air V air conditioner. I turn
Have fan start capacitor checked/replaced by licensed tech, or electrician as they are very dangerous to work with if not experienced and can give a very high voltage shock, that could be fatal. They basically store and increase voltage to higher range for start up of fan and compressor.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Carrier Air V in RV not working - 5 green blinking lights error
Call 1-866-464-2478, Mon-Fri, 8am-5pm. Have model numbers of lower (inside control box etc) and upper unit ready, and I'd ask for technical assistance. Good Luck.
Sep 05, 2009 | Heating & Cooling
Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Carrier Air V roof mount with remote. Does not cool. On light blinks 5 times then repeats blink code. What does the 5 blink code mean?
We have the same problem as of this morning . . . don't have the fix yet, but have located (2) manuals that I will enclose the links for. The 5 flashing green lights is mentioned in the "Service Manual" in Section 2 "Troubleshooting" with 5 possible remedies. Manual http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdf and Parts List http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298PL.pdf We're under warranty so will take our RV in ASAP
Mar 03, 2009 | Heating & Cooling
Compressor not kicking on
What type of thermostat are you using? When was the last time it worked ? Do you just get fan on cool mode, or does fan only run on fan mode?
Aug 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
925 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
