Question about TDK (CD-R21GXCB50) Storage Media
Micro sd 4gb down to megabytes - TDK (CD-R21GXCB50) Storage Media
I need password for sandisk 4gb micro sd memory card
i need to unlocked my 4gb micro sd memory card on asha 200 nokia phone
Aug 10, 2012 | Nokia Asha 200 Mobile Phone - Unlocked/No...
My lg800ghl doesnt except my micro sd card.tried formsting but still doesnt work and i get the micro sign with an x in the top rght cornor
Only a 4GB Micro SD works with this phone. I first tried a 16GB and it didn't register at all, but the 4 does. By the way, finding the Micro SD slot is also hard to find at first. It's located under the battery.
Aug 25, 2011 | LG KE800 Smartphone
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
How many minutes does it's 64 mb internal memory hold? It says it has a 64 megabyte memory without an sd card.
The internal memory included in that device isn't going to be good for more than a minute or two of video recording. Because of the detail required in video capturing as well as the audio feed that it has to record, the file sizes can get quite large. I would recommend grabbing yourself at least a 2GB SD card, and actually probably even a 4GB if you were looking for some longer record times.
Thankfully, SD memory has gone down in price CONSIDERABLY over the years, many retailers often have 4GB SDHC cards for $20 or less.
Hope this helps!
Dec 09, 2009 | Polaroid DVF130 Camcorder
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
Oct 02, 2009 | Samsung Cameras
Micro sd hc 4gb wont work.
THe HC chip set for SD's and micro SD's have different programming in them and are unfortunately not backwards compatable with a standard SD host port. For you laptop, I reccoment getting a USB SD chip adapter. They're only like $6-$10 depending upon the brand. For your phone, however, I reccomend you take it back to the store for a trade-in on a standard SD chip, or for a complete refund so you can buy one from a store that carries standards.
May 01, 2009 | SanDisk 4GB microSD High Capacity Memory...
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
My phone NOKIA 6300 could not find micro SD card. please what do i do?
If it is a 4GB micro SD card it won't work, a nokia 6300 doesn't accept HC (high Capacity) micro SD cards. Maximum you can use is a 2 GB micro SD card.
Don't forget to rate, thks
Oct 28, 2008 | Samsung SGH-D900 Cellular Phone
Micro sd card
yes 4GB is the maximun motorola specifiy using on the v3xx
Jun 23, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
TDK (CD-R21GXCB50) Storage Media Logo
20 people viewed this question
Top TDK Electronics - Others Experts
Alun Cox
 Grubhead
Grubhead
Sandy Moore
Sandy Moore
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
