Question about Toshiba Satellite Computers & Internet
How to install windows 7 from usb - Satellite Toshiba Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 2,003 Answers
Http://www.pcadvisor.co.uk/how-to/windows/3352054/how-install-windows-7-with-usb-flash-drive/
Posted on Feb 10, 2015
Tip
Windows 7,Linux and other OS install from USB Pen drive, Flash Drive
To Install Windows 7 via USB Flash Drive (Pen Drive)
You need:
USB Flash Drive (Pen Drive) minimum 4 gb for windows 7
Windows 7 ISO image file.
UNetbootin software download from here UNetbootin
Download the Unetbootin software, and open the file and click "RUN".
below window will pop
You can aslo install other OS's like linux etc etc. for Windows 7, click "Diskimage" radio button, locate or browse the ISO file of your OS by clicking "..." button.
select Drive: (in my PC usb drive is "I:" and press OK.
Next window looks like below picture
Wait till Installation Compleate.
after compleation. Click "reboot" to install to the same PC, or remove the Flash drive(Pen drive) and plug it to another PC or Laptop USB
and boot that System by USB Flash drive.
To do this Select the USB boot option from the BIOS. Or to boot from USB go through your Motherboard User Manual.
This method works on most of Machines with USB booting option.
I personally installed 100's of PC's via this method
thank you. Keep smiling. aaarwind
for other OS setup's via USB drive refer to below Website:
UNetbootin - Homepage
on Jan 20, 2011 | Computers & Internet
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
To reset password on windows 7
Have you lost windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Jun 27, 2012 | Computers & Internet
SIIG (JU-P50212) USB 2.0 Network Adapter
If you did a fresh install of Windows 7, make sure you install Windows 7 SP1.
A lot of Windows 7 drivers were not included in the original release.
http://windows.microsoft.com/installwindows7sp1
The manufacturer does not list a specific driver for this card( although it does list it as being Windows 7 compatable) so likely you will find it by updating Windows 7.
http://www.siig.com/hi-speed-usb-5-port-pci.html
Jan 05, 2012 | SIIG (JU-P50212) USB 2.0 Network Adapter
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Error: code0x80070017
When you install Windows 7 (or Vista) you may get the following message:
Error 0x80070017 Windows cannot copy files required for installation. These files may be corrupt or missing. Make sure all files required for installtion are available, and restart the installation Error code: 0x80070017
This can be displayed with error code 0x80070017 or error code 0x80070570 in Windows 7 or Vista
The cause is very simple and you can probably guess from the error code in the screenshot above. The cause is that Windows cannot verify the files.
Simple Solution
  • Burn or get a new copy of the disk (Burn at a slow Speed 2x and use a quality media like (Verbatim)
  • Or if you have a current Windows installation you can install from the hard drive or from a USB drive
Check out my article on installing Windows 7 using a USB Key USB-stick-from-windows-xp/">Install Windows 7 from USB Drive
Dec 25, 2010 | Computers & Internet
Tip
Install Windows From Usb Drive
Windows 7 can run on machines with lower specs than required for Windows Vista, and many users are actually finding it runs better than Windows XP on lower spec machines. It’s also ideal to run on newer netbook machines, but unfortunately many of these do not include a DVD drive so how do you install windows 7 on a machine without a DVD drive?
I spent yesterday researching this exact problem and I managed to install Windows 7 on my LG X110 netbook in around 20 minutes using a 4GB USB Drive. Setting up the USB drive to install Windows 7 was fairly easy in the end, and the installation was quicker than a DVD drive, so this method is perfect if you want to install Windows 7 quickly on several machines.
How To Install Windows 7 From A USB Drive
  1. Find a standard 4GB USB Drive and plug it into your machine
  2. Click Start in your enter ‘cmd’ in the run field. Once cmd is open type in ‘diskpart’ and a new window will open
  3. In the new diskpart window type:
  • ‘list disk’ : This lists all the disk drives attached to your machine
  • Look for your USB drive and note the number and then type: ’select disk #’, where ‘#’ is your USB disk number
  • then type ‘clean’
  • then type ‘create partition primary’
  • then ’select partition 1′
  • then ‘active’
  • then ‘format fs=fat32 quick’
Once you’ve finished these steps you then need to copy your Windows 7 files to the USB. To do this you have to mount your Windows 7 ISO as a virtual DVD. Doing this is easy:
  1. Install MagicDisk (free)
  2. once installed, right-click on MagicDisk in your system tray click on ‘Virtual CD/DVD-Rom’, select your DVD drive
  3. then ‘Mount’ and in the dialog window that opens up, select your Windows 7 ISO
  4. Now in windows Explorer, click on your DVD drive and you should see all the Windows 7 Files. All you have to do now is copy and paste all the files to your USB key and you have a Windows 7 USB Installation Stick!
  5. Install the stick in the PC you want to install Windows 7 on and boot up. Remember to change your bios to allow booting from USB
If you follow the steps above then you should have no problems installing Windows 7 from a USB key
on Dec 23, 2009 | Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
